Surely this must be the best bluetooth adapter ever for a B&O system simply because it truly is hidden! It's simply based on a 13 amp UK plug from Ruark...
http://shop.ruarkaudio.com/collections/spares-accessories/products/ruark-audio-bluetooth-adaptor?
BeoNut since '75
Would the ATV4 bluetooth to your headphones Elephant? As long as you put whatever it is into iTunes or watch from the apps on ATV?
It should work Elephant, a friend of mine, Perry uses his bluetooth Beats with his ATV4.
Or, you could always use the cable :) :) ;)
Fl_ip:There is a solution for that. Also tested by B&O
elephant:Web page reference ? BeoNut since '75
Fl_ip:Only on Retail. Http://www.telme2.com/tosblue-the-super-TV-sound-you-can-afford.html
Paul W:It should work Elephant, a friend of mine, Perry uses his bluetooth Beats with his ATV4.
