B&O Play TV audio out
This post has 1 Reply | 2 Followers
Ajal
Posts 11
Ajal Posted: Wed, Apr 27 2016 1:57 PM
  I am quite delighted with this TV, but I would like to feed front L and R channels via a separate amp. to my KEF 104s.
The best level 'out' is LINE, (the external amp is working at about third/half volume), but of course, this means I can't vary the level with the Beo4 remote.
I'm sure I'm not the only one with this problem - is there an easy fix?
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Ajal,
No problem, you can take an audio output to your amp from one of the RJ45 Powerlink sockets on the Beoplay V1 TV using the adapter and cable in the links below:-
1) Adapter: http://soundsheavenly.com/bang-olufsen/152-rj45-to-powerlink-compatible-clip-on-adapter-genuine-bo-product.html
2) Cable: http://soundsheavenly.com/bang-olufsen/110-5-pin-din-to-twin-rca-powerlink-compatible-to-non-bo-hifi-amplifier-receiver-etc-din-to-twin-phono.html
Only one adapter and one cable are needed for stereo sound.  You can either set this socket to "Fixed Line" output and control the volume from your amp, or turn up the amp volume and use the B&O remote to adjust the speaker volume.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (2 items) | RSS
