Please can anyone help. I have had 2 call outs from bang and olufsen and still can't get a picture or uninterrupted sound. I have a Samsung 4K tv in my lounge with the Sky HD 2tb box underneath, I am running a 7 meter HDMI cable and fibre optical cable down to my basement to my Beovision 7 mk2 (plugged into the dvi) It always used to work with my old box,when I go in the menu to Dtv it comes up Thompson skyHD mkii in the menu is this the right sky box?. I borrowed a neighbours amstrad HD box and it worked on the 720 resolution. The engineer suggested running a cat6 cable with 2 HDMI connectors and setting the resolution to 576 but I think I should be able to get 720 like before.
hope someone can help as my wife wants me to sell the lot
Derek
Hi Derek.
Welcome to beoworld.
Mddelweston:when I go in the menu to Dtv it comes up Thompson skyHD mkii in the menu is this the right sky box?
I'm not sure, but in any case, even if it isn't, this won't be the cause of you picture / sound issues. The selection in this menu is purely to allow you to control your sky box with the B&O remote (with the aid of an IR emitter connected to the BV7 and stuck to the front of the sky box).
Mddelweston:I am running a 7 meter HDMI cable and fibre optical cable down to my basement to my Beovision 7 mk2 (plugged into the dvi)
In my experience, anything over 5 metres can cause issues with HDMI. That's not to say it is always a problem as you discovered with your previous box, but your mileage may vary when using longer cables.
Mddelweston:It always used to work with my old box
Mddelweston:I borrowed a neighbours amstrad HD box and it worked on the 720 resolution.
It all depends on:
In short, even when a given cable appears to work in one configuration, changing the box (or the television) can result in problems not encountered before.
Your options would be:
Hope this helps.
Martin.
Thanks Martin for your quick response,you have given me hope
Hi Derek
I have sky hd box and source is set as Thompson hd which is correct also as I said to someone else Amstrad is now part of sky tv
malcolm
