Beoport
This post has 3 Replies | 0 Followers
david707
Posts 146
david707 Posted: Mon, May 2 2016 8:55 AM
Beoport does not  have an Video output so how is Beoplayer presented on the TV screen for navigation?
Yendys
Sydney
Posts 312
Yendys replied on Mon, May 2 2016 9:04 AM
Beoport must be used with a PC up to Windows 7 from memory. If you want it display onto your TV then you'll have to connect the PC graphics output to the TV
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Mon, May 2 2016 9:40 AM
I initially said that there was only Windows XP drivers available for BeoPort and I was quite sure that it has been so for quite many years but I also now noticed at the support page that the BeoPort software supports Windows XP, Windows Vista and Windows 7.
david707
Posts 146
Thanks for this. If the graphics card is the video feed for the TV I assume only one TV can be used - or can this be viewed on link TV's also? I can see how audio distribution would work via ML but how would you be able to navigate the system for e.g. from a link room without being able to see the the same interface that is presented on the PC? You would also need additional RF cable from the PC to the TV.
Page 1 of 1 (4 items) | RSS
