Beogram 3000 (type 5228) runs fast
This post has 24 Replies | 1 Follower
Saint Beogrowler
Saint Paul
Posts 780
Saint Beogrowler Posted: Tue, May 3 2016 2:47 AM
Hi. I received a Beogram 3000 type 5228 from the early 70's that runs too fast. I received this beauty in exchange for fixing a Sansui receiver for a friend.
Saint Beogrowler
Saint Paul
Posts 780
With the thumb wheel timing adjuster as loose as it goes I'm still getting speeds of 35+ and when I tighten it I get speeds around 40.
I cleaned and oiled the motor.
Put rubber conditioner and wiped down the 'idler?' wheel rubber which looks good. I tried to loosen the cone coming up from the motor and push it down to allow the wheel to move up higher and have less pressure to let it slow down some. If I'm understanding this function.
Saint Beogrowler
Saint Paul
Posts 780
If I put the right amount of pressure on the speed thumb wheel I can hold it to maintain a speed of 33... But on examination the wheel doesn't move any lower.
I tried stretching the belt, which the previous owner was unsure if it was the right belt, by stretching it around a large Dutch oven and filling it with boiling water and letting it sit for a few hours but that did nothing.
Is there any thing else I can try before trying to buy a new belt?
Søren Mexico
Mexico City
Posts 6,411
Check the tongue that lift the idler wheel up and down, I repaired on like this. And check here for the whole thread
Saint Beogrowler
Saint Paul
Posts 780
Right on Søren! Here is what my tongue looks like
How thick was the plastic you used? It looks like it is just a bit higher sitting than the rivets from your pictures. Also, was it a rigid or soft plastic?
Thanks for sharing that thread, lots of very helpful information. I'm enjoying working on this era of equipment right now.
Søren Mexico
Mexico City
Posts 6,411
Your arm doesnt look too bad, just dirty, The position of the idler wheel in your pic is just about where I have mine with correct speed adjusted, but it looks like the idler wheel is pressed very hard against the motor pulley, I still have the original belt and it is quiet loose, but working OK, also check the whole drive mech. it has to move lightly in all directions (dismantle, clean and lubricate)
My plastic piece is around 1,5 mm thick, normally there is a round fiber disc attached
Saint Beogrowler
Saint Paul
Posts 780
Is there suppose to be more than the copper plate? The little nub in the hole is rotten and I can't really tell what it use to be made of? Here is a shot of it wiped off and the little nub.
I'm in the middle of the thorough clean and lube, I like this stage. It all seems to move pretty freely but with the excessive pressure on the idle wheel could that be a too tight of belt?
Saint Beogrowler
Saint Paul
Posts 780
Round fiber disk. Reread, got it.
Søren Mexico
Mexico City
Posts 6,411
Mine tongue was totally worn down, in your case I would find a fiber disc or hard nylon washer and epoxy it. with my belt attached there is no visible deformation on the idler wheel, so you may have a belt problem
Saint Beogrowler
Saint Paul
Posts 780
Thank you Søren for all your timely help!
Felt tipped:
The speed control still needs to be as loose as possible but now speeds in the upper 33 to low 34 are maintained and are not noticed by my amateurs ear. Will follow up with a report after I order a new belt. But for now we are in operation!
Carlos Santana agrees.
It sure looks big next to the Beomaster 4000.
Saint Beogrowler
Saint Paul
Posts 780
So, 4 months later this BG3000 still plays too fast and before I drop some dollars on a really nice SP12 repair I want to get this properly fixed. New belt from Martin which fits amazing!
Doing some reading and it seems my problem is that this is a 50hz deck in a 60hz country. I was reading this amazing post by Soren Mexico, http://archivedforum2.beoworld.org/forums/p/1666/14226.aspx#14226
and I wonder if this will work for me too?
If I just pull my belt drive wheel and have someone 3D print me one that is 20% smaller would that work?
Søren Mexico
Mexico City
Posts 6,411
Yes this will work, my 1202 has been working ever since, no problems with the speed what so ever and the motor works at normal temp, even after 3-4 hours continued playing.
When doing the 3D dimension change make sure you only change the 20% on the diameter.
Good luck
Saint Beogrowler
Saint Paul
Posts 780
Thanks for the response Søren, very good advice- I would have overlooked that. I have a math teacher friend who is looking for 3D printer assignments for his students.
Saint Beogrowler
Saint Paul
Posts 780
Søren, how did you remove the shaft from the original?
Søren Mexico
Mexico City
Posts 6,411
Measure and note the position then just bang it out, it is a press fit.
The original wheel is made of 2 steel plates fitted to the center of aluminum.
To get the right position on the shaft I turned the center top down to the difference between the outside of the belt track to the shaft center
Instead of the 2 pegs I made a "skirt" on the wheel, the idler wheel center has to enter freely in the skirt
Make sure you get the drive pin hole in the right position, the hole is bigger than the pin so + - 0.2 mm is OK
I drilled out the center hole to the same dimension as the shaft, with polyamide this gives a press fit, after tests I just secured it with 2 drops of super glue after cleaning with acetone
Saint Beogrowler
Saint Paul
Posts 780
Apparently the BG 3000 used a lighter softer metal
Failure here.
Søren Mexico
Mexico City
Posts 6,411
You are hitting on the wheel, put a piece of tube that fits over the shaft in a vise, tighten hard, put the long side of the shaft inside the tube, hit the shaft with a plastic hammer or a piece of hardwood and a hammer, when the shaft is even with the center use a mandrel for the rest.
If you didnt take all the measurements before, you are in trouble now
Saint Beogrowler
Saint Paul
Posts 780
Measurements were indeed recorded prior to the pressing and we will see how much trouble I'm in yet.
Mine had a toothed ring in between the layers of the pulley that were gripping on the teeth of the shaft. My first two poundings were taps with a piece of wood against the shaft and a soft roll of tape against the pulley that must have been too wide. That technique deformed it as seen in the prior pictures. When poundings the right way as Søren described I was able to break that inner ring.
Saint Beogrowler
Saint Paul
Posts 780
Almost there!
Mennahem knew a guy who was looking to get rid of some parts to a 60hz table. Parts arrived last night, pulley was the exact size I needed. Using Martin's new belt (fantastic that these are available now! You should buy one) it's up and running and playing at appropriate speeds.
Dried rubber on the idler pulley is a little noisy, I will have to get that reconditioned yet and the RCAs and power cord could use a replacing to get it closer to perfect, and the tonearm doesn't always return, probably use better cleaning and oiling. But it's so close and playing great right now.
Only thing will be to find new bearings for the motor for long life and then I'll upgrade the cartridge.
Peter
Earsdon
Posts 11,991
Peter replied on Tue, Mar 14 2017 9:47 PM
These are great decks - probably the third best Beogram 3000! But the best actually properly made by B&O! The 2000 looks even better but the 3000 sounds better.
Peter
Saint Beogrowler
Saint Paul
Posts 780
What makes this table sound so good? I'm am assuming it is because it was such a journey to get here hat I like it so much.
I've been side by side comparing this to a TX with mmc3 this afternoon and the BG3000 sounds deeper with less surface noise from the same albums. I would think compared to numbers and technology it wouldn't sound so good. I probably have tweeting I will still do to both decks yet though.
Peter
Earsdon
Posts 11,991
Peter replied on Wed, Mar 15 2017 9:25 AM
Better record support for starters. The SP cartridges are also excellent - my best deck is the Thorens Beogram 3000 which uses a 12" version of the B&O arm and an SP2 - the record support is much better again and the bass is very extended in comparison to most Beograms. The suspension is clearly not the same so it is mounted on a rigid wall bracket.
Peter
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Mar 15 2017 9:48 AM
Plus, perhaps, a general change in sound taste and greater attention to fidelity.
The newer decks are designed to sound linear, the older decks pleasant.
the_o_master
Posts 856
Peter:
Interesting. I always thought Beogram 1202, Beogram 2000 and Beogram 3000 (not the Thorens and not the acoustical) are all the same decks with only visual differences (the 1202 and 2000 with a platter with “pegs” to hold the record and 2000 with part of the in black instead of silver to match the Beomaster 2000).... Unsure
Vintage Bang & Olufsen
rene grondin
northern quebec canada
Posts 10
I resolved the problem with good quality shrink tubing, no noise no speed problem.
Page 1 of 1 (25 items) | RSS
