MCL2AV Type 2026 - SW2.3 - polarity of the DC power input
This post has 1 Reply | 2 Followers
kallasr
Germany
Posts 2,562
kallasr Posted: Thu, May 5 2016 3:26 PM
Dear Forum,
since my newly added MCL2AV has got no power adapter, I just bought one from Amazon.
Now the question is: what polarity do I need to use?
I will try to use the MCL2AV with transceiver to use a second Beosystem in my Office (Link Mode).
Thanks for your help!
Ralf
RaMaBo
near Munich
Posts 626
RaMaBo replied on Fri, May 6 2016 11:39 AM
Hello Ralf,
for the power connection you need the polarity scheme on the right side. The positive 15 V has to be on the outer connection and ground has to be on the middle hole of the power cable.
The MCL2AV power connection has the ground at the center pin and the +15V have to be supplied via the shield connector.
Ralph-Marcus
Page 1 of 1 (2 items) | RSS
