Beosound9000 Serial Number
genius
Posts 3
genius Posted: Wed, May 11 2016 3:09 PM
Hey there!
Does someone know where I can find my Beosound9000's serial number?
Thx!
zerocool143
Posts 94
Make sure that both of them are connected on the same network.
The NL/ML should be in VMaster role.
Try to turn on the option of the Beosystem 4 Wake up on lan
Menu>Setup>Power Saving> Network
genius
Posts 3
genius replied on Wed, May 18 2016 2:15 PM
Thanks! Unfortunately, my setup still doesn't work, even though it's configured as you suggested. The system log still tells me that ML Audiomaster doesn't exist...
zerocool143
Posts 94
Try to turn of everything first.
Then turn on everything one by one
BUT the NL/ML should be the last device to be turned ON.
IF this doesnt work. Try to reset the NL/ML and reconfigure it again
Page 1 of 1 (4 items) | RSS
