Could somebody please tell me if the following setup is possible?
I have a Beosystem 7000 in the living room and a Beosound 9000 in the bedroom.
Would it be possible to link those products using ML Converter linked to the AUX socket of BM7000 to listen to CDs from BS9000 in the living room?
I assume this would require to set the BS9000 as audio master and the BM7000 as a slave.
I know that I could use crossed 5 pin DIN to link those systems bus AFAIK the BS9000 does not support Datalink so remote control wouldn't be possible.
Thanks in advance!
I have not tested this myself yet, but I also would like to have a setup like this for a temporary solution. My understanding is the the Beolink Converter can be used for this (types 1611 or 1612). The manual shows that you connect both the aux and powerlink to the BM7000 and of course the ML to the BS9000. The BS9000 defaults to option 0 when there are no speakers connected to its powerlink sockets, and the BM7000 should already be in option 1.
Someone else with direct knowledge should be able to offer advice on how to control the BS9000 CDs from the BM7000. I would assume that the BS9000 is treated as a video device?
