I have just set up my new A9MK2 and am very excited. It sounds fantastic and works very well.
Unfortunately, I have some issue with it. Deezer does not work when played over the Beomusic app. Each song plays for around 30sec and then skips to the next track. I only have the free Deezer if this helps for problem-solving. Interesting enough, I can play Deezer on my iphone. Also, I can play deezer on my iphone and then airplay it to the A9 and this works properly. The only thing that is not working is deezer when playing on the A9 from the Beomusic app.
Any thoughts highly appreciated! Thanks in advance.
Did you configure your Deezer account also in the A9 (through beosetup or the webpage ?)
Your problems sounds like it isn't.
Christophe.
Beolab 1, Beovision 7-32, Beosound Moment, Beolab 18, Beolab 19, Beoplay A6 Grey, Beoplay A6 Black, Beolit 15, Beoplay H7, Beosound Essence mkII waiting for speakers :)
I think I know what the issue is and it is actually expected behavior.
Deezer via Beomusic only works with a premium Deezer account? With a regular one, I can only use the Deezer app and airplay.
Correct?
Correct. Deeper has to sell Premium accounts
diisign.com
Sure. Hope they will also agree on higher-quality streams with B&O soon.
steve1977:Sure. Hope they will also agree on higher-quality streams with B&O soon.
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
steve1977:I think I know what the issue is and it is actually expected behavior. Deezer via Beomusic only works with a premium Deezer account? With a regular one, I can only use the Deezer app and airplay. Correct?
