Connecting Apple TV to Beovision 10
This post has 7 Replies | 3 Followers
Belord
Posts 1
Belord Posted: Mon, Jul 23 2012 3:52 PM
Hi all,
I want to connect Apple TV to my Beovision 10. However,i have the model with only 2 HDMI sockets which are already in use and I do not want to constantly unplug . I believe what I need is an HDMI expander. Can anyone recommend one that is compatible with the Beovision 10
kokomo
Spain
Posts 206
kokomo replied on Mon, Jul 23 2012 4:44 PM
Hi & welcome.
The Neet - 3 port auto switch box is well regarded. Cheap too. Great reviews on Amazon.
hfat
Vienna, Austria
Posts 663
hfat replied on Mon, Jul 23 2012 4:45 PM
hi,
This one will work with B&O:
http://www.gefen.com/kvm/dproduct.jsp?prod_id=9151
but you need the PUC added to your system.
hfat
bud
Milton Keynes
Posts 5
bud replied on Mon, Jul 23 2012 4:49 PM
CYP do a great range and seem pretty solid.Wink
BeoHut
Posts 482
BeoHut replied on Mon, Jul 23 2012 9:14 PM
I use the GefenTV, works perfectly with the PUC installed.
Here is the product: http://www.gefen.com/kvm/dproduct.jsp?prod_id=9556
wesheltonj
Texas
Posts 22
Altona AT-HD4-V41 was the recommended by B&O USA.  There is an PUC code that your dealer will have to install.  Hope that helps.
http://www.atlona.com/Atlona-4-by-1-HDMI-Switcher.html
BeoSystem 5500, BeoVision 10-46, BeoLab 8002
Apple TV
Samsung BD-D7500
Wii
Flappo
Posts 850
Flappo replied on Tue, Jul 24 2012 7:46 AM
Why not trade it in for a new one ? I thought the whole point if buying bno was their supposed resale value compared to other brands.
Its probably worth millions by now. You coud probably get a rolls Royce phantom , a Bugatti veyron and half a dozen British banks while you're at it. And get change.
butch1
Posts 384
butch1 replied on Tue, Jul 24 2012 8:54 PM
If a bv10 is a tarted up samsung,  and a audi is a tarted up skoda,why does the former hold its value better.
desirability,would you rather have a brand of tv that you can pick up in the supermarket ie samsung in your house,or something a bit exclusive,that you are proud to own,and looks different and unique.,
I would rather drive a audi,even though I know it shares its engines and chassis with the rest of the vw group.Thats brand value for you.B&o know how to do this.To make it desirable(apart from playmaker).
Page 1 of 1 (8 items) | RSS
