Hi all,
New member here so go easy on me :)
I have inherited a B&O Beolab 5000 amplifier and a few cables, alongside a vintage SONY tapedeck from my father-in-law. He says he purchased it sometime in the 'early 70s' and has had it in storage since then. He reliably tells me that it works a treat and is very powerful.
"Back in the day it was the top of the range" etc... you get my drift. :)
Anyhow, how stumbled upon this forum looking for a place I can glean some advice regarding whether I should hang on to it, or indeed if it's worth anything, perhaps a future sale?
I really don't have a clue as to what these things are worth, other than the one currently on eBay for £300 with no bids (lol) - so I'm not using that as a benchmark.
The only real keywords I keep coming across relating to this product is 'Sacred System' and 'True Classic' and the odd 'Legendary' here and there. :)
Keith from this site kindly advised I should head over here and see if I can pick a few people's brains about it. I'll be honest, I don't even know what I should be asking, but here is the spec as I see it:
Teak wooden panel. Powers up fine when switched on. No buttons stick. Silent. Very heavy unit - solid build. No dents. A bit dusty so could probably do with a clean. Service history - none that I know of other than my father-in-law is very careful with his electrical equipment, it will have been looked after. No Box or paperwork. One short chunky grey 5-pin DIN(?) connector cable. BL 5000 Type 5303. No. 47286.
Some pictures for you - hope I'm not breaking any rules. Apologies If I have. EDIT: The photos seem to have been cropped I guess because they are too wide. You can see the full version in the MEDIA GALLERY on this site - Keith very kindly added them there earlier.
Hello and Welcome.
The Beolab 5000 is a brilliant amplifier. One of B&O's best ever and I would personally recommend keeping hold of it.
In terms of value, difficult to say really. There have been a few on eBay recently but I am not convinced they have all sold. Either way, my recommendation is to keep hold of it, especially if it works.
Frede can perform a full restoration as well and further details on this can be found on his website (classic audio).
Nice pictures too!
Ben
Thanks for the response Ben - appreciated.
Thing is I'm not sure what I can use it for, as I have no tapes to hand. I have a couple of old Dynatron speakers that came with it, with no cables though. Looking at all the connections on the back of the 5000 kinda turns my brain to mush. :)
I guess they'll go up in value though yes?
Here is what I did to mine, and I had to do it
Wow - I've only perused the first page of that thread and I can see I am a year too late!
Makes me appreciate how well kept my unit is. Thanks for the link to your thread - I'm keen to read through it and see how you managed with the restoration.
Jacques
