BLGW if else statements and other questions...
This post has 3 Replies | 2 Followers
Chris Hassell
London
Posts 396
Chris Hassell Posted: Sun, May 22 2016 11:41 PM
Hi there, wondering if anyone can help with these...
- What use is the virtual LED switch? Is there an efficient way to use it.
- I assumed the above virtual button would be used for a light on/off switch. Leading on from this, is it possible to use the same resource for on AND off functions.
- leading even further on from the above, is it possible to create anything like IF and ELSE statements. So for example IF TV is on then an event does something but IF Music is on it does something else. Is there a clever workaround using macros I'm not thinking of?
- is it possible to toggle through sources (or anything else) with a single button? So for example to replicate what the top button of a BT Essence Remote does by default.
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
mjmedlo
Posts 922
mjmedlo replied on Mon, May 23 2016 2:35 AM
Join cycles through sources.
Can't help you with the rest.
Chris Hassell
London
Posts 396
mjmedlo:
Cheers @mjmedlo - I'm thinking something that would cycle like 'join', going through lighting scenes for example.
mjmedlo
Posts 922
mjmedlo replied on Mon, May 23 2016 10:50 PM
Unless your lighting source has the cycle option I don't see how you could do that?
Page 1 of 1 (4 items) | RSS
