Simple question... has anyone tried dyeing B&O stock-white frets? I was thinking of dipping mine halfway into a bath of heavily diluted dye to achieve that sort of subtle Nordic sky colour appearance.
The main concerns here are that I'm not exactly sure if I need to go with a more specialized solution that is capable of dying polyester/nylon, if the fabric will retain its audio transparency, and if it will even work at all.
Appreciate the help!
View this post at http://archivedforum2.beoworld.org/forums/p/15622/135035.aspx#135035
