Problem with HDMI splinter BV7 40
This post has 3 Replies | 0 Followers
Silou
Switzerland
Posts 465
Silou Posted: Fri, Jun 3 2016 12:28 PM
I'm using a BV7-40 (DVI) and connected a HDMI splitter.
Picture here but with some white horizontal line every 5cm approx.!!! (with and without 2 output connected)
Same problem with other cables and with another splitter...
Of course picture ok witout the splitter.
Does anyone has some experiences with splitter?
The Beonic Man
Bristol
Posts 812
I used an Atlona 3 way HDMI splitter when I had my BV7-40 III ten years ago without any problems at all. In fact I highly recommend it and may still have it in the garage somewhere. What makes you think the splitter is causing signal or picture interference? Simon.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.
11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
Silou
Switzerland
Posts 465
Silou replied on Sat, Jun 4 2016 3:44 PM
Thanks for your answer.
Tried all cables without splitter, and the picture is always fine! Changed the splitter with another one, same problem -> I think that something is wrong between the BV and this splitter.
BeoIce
Recklinghausen, Germany
Posts 751
BeoIce replied on Sat, Jun 4 2016 5:06 PM
There's a hdmi switch from Gefen around which is supported by the BV7 if your software is up-to-date.
Don't know the excact model, but you might do a search here or on the archived forum.
EDIT: Did a quick search and found this
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
Page 1 of 1 (4 items) | RSS
