What is the better way Beosound essence slave or master
This post has 23 Replies | 0 Followers
JpV
France
Posts 22
JpV Posted: Mon, Jun 6 2016 3:07 PM
Hello,
In some weeks I will have the Beosound essence. I would like to know what the best way slave or master ?
I have a Beosound 4 , HP computer , Android Samsung telephone, Samsung Tab 3 and a Sony TV.
2 Beolab  3 and 1 Beolab 11.
Have a good day.
Millemissen
Flensborg, Denmark
Posts 14,680
Wondering what you mean by 'slave or master'???
Normally the terms 'slave and master' are represententing how devices in a MasterLink-seup acts.
This is different in the NL-world!
You might say that there are only 'masters' in a B&O networklink setup.
JpV
France
Posts 22
JpV replied on Mon, Jun 6 2016 4:14 PM
Thanks.
I would like to know the best to connect the Beosound 4,  the beolab 11 et 3, and the TV (with RCA). Sorry, for y bad English.
Big Smile
Millemissen
Flensborg, Denmark
Posts 14,680
Thats perfectly ok!
One way you could do it, is to use the PowerLink-out (you'll need an adapter cable) to connect the Essence-box to the Aux-input of your BS4.
Note: the Essence will have to be configured as 'fixed line-out' and you won't be able to use the 'wheely-remote' for volume controlling! This will have to be done with the BS4.
The Essence has a line-in connection, which has autosense (means it turns on when a signal is detected).
This can be used for the connection of the tv - RCA out (volumen fixed - controlled via the BS4).
Your speakers then connected to the BS4 = BS4 -> BL11 -> BL3.
The functions/sources of the Essence must be controlled via the BeoMusic app respectively with the 'wheely'.
Look here for further inspiration:
https://beocincinnati.zendesk.com/hc/en-us/article_attachments/201492343/BeoSoundEssence-InstallationGuide.pdf
BEOVOX141
Denmark, West
Posts 711
@JPV
Just wondering, - with the B&O products listed, where would the Essence come into play?
What are you trying to achieve? Smile
Razlaw
Posts 4,345
Razlaw replied on Mon, Jun 6 2016 9:46 PM
Millemissen:
I have an Essence connected to the aux in on my Beosound 5. I can use the volume wheel in the app to adjust volume although I have a maximum volume set in the settings of the BeoSetup App. If the volume is set to high  on the Essence there is distortion and and static in the sound. Maybe I have it set up wrong?
Razlaw
Posts 4,345
Millemissen:
Razlaw
Posts 4,345
Razlaw replied on Mon, Jun 6 2016 9:49 PM
Took a look at my settings in the BeoSetup app. If I select Line Out Level, it says Use Power Link socket for connection to anode system instead. I am using the Power Link socket to connect to the Beomaster 5?
Millemissen
Flensborg, Denmark
Posts 14,680
@Razlaw
I have the box: 'connect...to another system' ticked.
The volume-output is fixed and has to controlled by the BM (to which it is connected/Aux-in),
and it is how I want it.
I have no 'wheely' right now to test it, but I can't imagine that the volume control there should do anything, since the same control in the app also does nothing.
It wouldn't be desireable to have two volume controls in one system either!
By the way - this is example 3 in the above linked document!!!
Razlaw
Posts 4,345
Razlaw replied on Tue, Jun 7 2016 12:38 AM
I do not use an essence remote, but the volume wheel works. If I have aux in activated on the MasterLink system, and then use the app to also turn on my V1 wirelessly connecting to the Essence, I can select group and then there are two circles in the app volume control. Moving them together adjusts the volume on the V1 and the ML system simultaneously.
Razlaw
Posts 4,345
Razlaw replied on Tue, Jun 7 2016 12:54 AM
I went back into settings and next to the line message, what I thought was just an indicator, was in reality a box I could check. Checking that box did disable the volume feature of the app as well. That would appear to be the correct way. Thanks. But if the box is not checked, then the app can control the volume, although turning up too high in the app does seem to affect sound quality.
Thank you again for directing me to the right/better setting.
JpV
France
Posts 22
JpV replied on Tue, Jun 7 2016 6:41 AM
Thanks, for this complète answer.
JpV
France
Posts 22
JpV replied on Tue, Jun 7 2016 6:53 AM
When I receive the Beosound essence, I will say to you how I configured it.
Thanks all
CB
> You are Here <
Posts 1,762
CB replied on Tue, Jun 7 2016 9:37 AM
I was using my Essence as "master" with a BS Ouverture, i.e. as main gear, BLs plugged in it, Ouverture plugged in the Essence Line in.
I think it depends on your way to use your equipment...
If you're mainly listening to networked sources (internet radios, NAS) it's better like this (you don't have to turn on other equipment).
If you're mainly using your BS4 (CD), then plug the Essence in the Line in of the BS4, not the contrary.
The sound quality may not be that different (it's simple to check this point by a trial).
My 0.02€
Millemissen
Flensborg, Denmark
Posts 14,680
Sure that would be a(nother) way to use it.
Since I still have a couple of masterlinked rooms (and even a MCL-room), I choose to do it the other way 'round.
That way I have the sources of the Essence available in all rooms...
....including in the room with my new (second) tv, the V1-32 (without having to use the converter).
The Essence is a very 'flexible' device - fits in everywhere ;-))
JpV
France
Posts 22
JpV replied on Tue, Jun 7 2016 11:16 AM
Thanks CB.
JpV
France
Posts 22
Thanks CB.
JanHalsey
Posts 1
Hi everyone...as per my experience one way you could do it, is to use the PowerLink-out (you'll need an adapter cable) to connect the Essence-box to the Aux-input of your BS4.The Essence will have to be configured as 'fixed line-out' and you won't be able to use the 'wheely-remote' for volume controlling! This will have to be done with the BS4. The Essence has a line-in connection, which has autosense.
JpV
France
Posts 22
JpV replied on Thu, Jun 9 2016 7:11 PM
How configure the beosound esence for use the "wheely remote"  volume ?
JpV
France
Posts 22
JpV replied on Sat, Aug 27 2016 5:17 PM
How to " fixe line-out" on the Essence? Can you give me the solution?
Thanks.
CB
> You are Here <
Posts 1,762
CB replied on Sat, Aug 27 2016 8:07 PM
JpV:
Bonjour JpV
Il faut d'abord appairer la télécommande (en bluetooth) avec l'Essence. C'est détaillé dans le petit guide fourni avec la télécommande, ou téléchargeable chez B&O.
Ensuite... C'est tout !
CB
> You are Here <
Posts 1,762
CB replied on Sat, Aug 27 2016 8:15 PM
JpV:
Dans les paramètres de l'Essence, avec l'application BeoSetup impérativement (donc pas l'App Beomusic), il faut régler le volume sur le mode "hôtel".
Mais alors le niveau du son ne sera plus réglable avec la télécommande...
JpV
France
Posts 22
JpV replied on Sun, Aug 28 2016 8:51 AM
Merci pour la réponse rapide. Je voi cela demain.
U
JpV
France
Posts 22
JpV replied on Tue, Aug 30 2016 6:57 AM
Thank you all. It work well.
Have  a good Day.
Page 1 of 1 (24 items) | RSS
