In need of a CCH2 valve
This post has 5 Replies | 2 Followers
kevinsmith1
Posts 2
kevinsmith1 Posted: Tue, Jul 24 2012 10:38 AM
I have been asked to restore an old Beolt '39 radio and have identified that the CCH2 valve is shot!
Does anyone have information where i can get another one from (or an alternative UCH4   UCH21   ECH3 )
Any assistance would be gratefully recieved.
Kevin Smith
chartz
Burgundy, France
Posts 4,171
chartz
Burgundy, France
Posts 4,171
kevinsmith1
Posts 2
Thanks for the link. I'll update on progress when there is some.
Kevin
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Jul 24 2012 6:07 PM
CCH2 is very rare to find and the used ones that pop up occasionally are usually bad.
I used an ECH3 instead when I did a Beolit 39 a couple of years ago and it worked wonderfully.
(A resto-thread can be found in the archived sections though the photos seem to have disappeared).
The function of the ECH3 is very close to that of the CCH2.
Most functions and specs are the same, even the pinout is an exact match, only
the heater voltage is different.
The heater current, fortunately, is the same which makes life much easier when dealing
with a set with a series heater chain.
The CCH2 heater takes 29 Volts, the ECH3 only 6,3 Volts so the dropper will have to
be changed to suit this new situation.
Ohms law in action; We have to drop (29-6,3) = 22,7 Volts.
With a heater current of 200mA, the resistor calculates to (22,7/0,2) = 113 Ohms
The power handling of the resistor should be no less than (22,7x0,2) = 4,5 Watts
ECH3 is far more plentyful than the CCH2, even NOS ones can be found many places.
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Jul 25 2012 5:13 AM
Ah yes the good old ECH3! I must have one of those in a box somewhere...
Thanks for the tip Martin!
Jacques
Page 1 of 1 (6 items) | RSS
DigiCert Secured Site Seal
