does anybody have a Service Manual for my BV7-40 MKIII for me ? The type is 9383.
I didn´t find the file into the "User & Service Manuals" Section.
I need to find the issue regarding a "no picture" fault, even that the backlight is working.
Thx/Regards
Tom
Tomvdw: Hi, does anybody have a Service Manual for my BV7-40 MKIII for me ? The type is 9383. I didn´t find the file into the "User & Service Manuals" Section. I need to find the issue regarding a "no picture" fault, even that the backlight is working. Thx/Regards Tom
Good evening.
The service manual is now in the User & Service Manuals section. It is in Danish, however. Use the MkIV manual for the translation as both TVs are similar (although not identical: the LCD panel, PIM module and Blu-Ray player (MK3 has a DVD) are different).
Good luck,
Jean
Hi budy, anyone have beovision 7-40MKIII/MKIV service manual, mybeovison open switch on few minutes it will screen shut down, and the standby red light on.
