Hi Chris,
get an Earset 1 (left or right) for her. The version for the Serene should also work with other phones with a 2,5 mm plug connector. If necessary a 3 pin adapter from 3,5 mm tip to 2,5 mm could be used.
Ralph-Marcus
The Earset 3, Earset 3i, Beoplay H3 and Form 2i are great lightweight headphones/earphones for both taking calls and music.
//EA
Beo in white is my thing
Currently own: BeoVision Avant 55", BeoLab 5, BeoLab 18, BeoRemoteOne, BeoPlay V1-32", BeoRemote4, BeoSound 3200, BeoGram 6500 (MMC-1), BeoLit 15, BeoPlay A1, LC2, BeoVision MX7000 and BeoLab 3
I use my H3 ANC for calls all the time. The only trouble is that it is hard to hear myself talking (even when the ANC feature is off).
The transparency of the A8s and Form 2s make it much easier to hear myself speak.
Beo4 'til I die!
