Beosound 5 App
This post has 77 Replies | 9 Followers
DoubleU
Posts 562
DoubleU replied on Mon, Jul 30 2012 7:44 AM
Even if this app works with the speed of a Sonos controller and it is something you want, then isn’t the BS5 a bit overpriced?
And does the MOTS still work if you use this app?
TWG
Posts 1,672
TWG replied on Mon, Jul 30 2012 9:17 AM
I can't get it to work!
Is there anything I have to take care of during the configuration?
My Beosund 5 / Beomaster 5 combo is set up as follows:
- Musicserver ON
- HOST Name: custom (not Beomaster5)
- CLIENT Password enabled
Does the application only work when the Beomaster 5 Network access is NOT password protected?
Barry Santini
New York
Posts 543
I think the Creation app is just an auxiliary software/DLNA controller. I believe you need to have both a BS5 and a BM5 for it to work.
B
TWG
Posts 1,672
TWG replied on Mon, Jul 30 2012 12:40 PM
bsantini:
B
I have a Beosound 5 with Beomaster 5. Edited my post.
Fisp
Denmark
Posts 75
Fisp replied on Mon, Jul 30 2012 2:38 PM
TWG:
- Musicserver ON
I had the same problem. Restarting the server helped.
Fisp
Denmark
Posts 75
Fisp replied on Mon, Jul 30 2012 3:02 PM
I have tried Creation 5 and I'm not convinced that it's worth its price compared to other controllers like PlugPlayer and eLyrics.
However, with all of these I have one problem that has made them useless to me.
I have converted my CDs (almost entirely classical music) to FLAC format and when played from the BS5/BM5 I get the exact same result as when played from the original CD. I.e. no gaps.
When played from Creation 5 (or PP/eLyrics) all tracks on the CD/album are interpreted as one separate "album" each separated by a pause and getting the cover art one more time. Moreover all tracks are in complete random order.
What causes this change of output from the BS5/BM5 to Creation 5 and how do I ensure that my albums are played correctly on both platforms?
Thanks.
Fisp
Denmark
Posts 75
Fisp replied on Mon, Jul 30 2012 6:46 PM
Well, I have now looked around to find a solution and the simple answer is that PlugPlayer and the likes are not able to play gapless. Sad
jhamers
Posts 35
jhamers replied on Tue, Jul 31 2012 8:09 AM
No. When using the app, none of the features of the BS5 are available, the app takes over as a controller. The app needs to be running all the time too because it keeps an eye on the song that is being played and if it's done, it will skip to the next song. I have a feeling the app is responsible to do that and not the BS5/BM5.
TWG
Posts 1,672
TWG replied on Tue, Jul 31 2012 12:26 PM
to all members where the software works:
How is your Beosound 5 / Beomaster 5 configured?
- Client name?
- Password?
My Beosound 5 is configured to
- Musicserver on
- Clientname: custom
- Password protected
and on the same network as the iPad with Creation 5 software but it does not work. The software only displays "finding Beosound 5" and nothing more. I rebooted the Beosound 5, rebuild Musicserver but nothing works.
What is the original name of the Beomaster in the network menu? Beomaster5? or Beomaster_5 or Beomaster 5? :-)
nico vercammen
Elversele, Belgium
Posts 174
I have the same problem ... the app is not working(currently finding your beosound 5 ...).
My network is a bit more complex than a standard Ip network, but i do not see where the problem can be.
I guess the app is broadcasting something on the network and can not receive an answer from the BS5
I wrote them an email to ask some help.
nico
claudiu
copenhagen
Posts 193
claudiu replied on Tue, Jul 31 2012 12:48 PM
Audio master   have to be to YES
mjmedlo
Posts 922
mjmedlo replied on Tue, Jul 31 2012 2:48 PM
I ran the app for a couple days then turned it off for  a day.
Then back on again.
No problems at all for me.  It worked the first time I turned it on.
There is a 'help' section on the app and I found it helpful.
Fisp
Denmark
Posts 75
Fisp replied on Tue, Jul 31 2012 5:31 PM
It worked after restarting the server, but after shutdown I'm now back to "Finding BS5"
And it cost me 50d. Angry
nico vercammen
Elversele, Belgium
Posts 174
claudiu:
hmmmm..... Tried as audiomaster than it works. But I do not want to giveup my BS9000 ....
Nico
claudiu
copenhagen
Posts 193
You don't have to give up anything.
Beosound 5  in option 0, and you will have to press 2 times to activate radio. otherwise e
verything will work.
Creation
Posts 9
We recently became aware that there was a forum topic about the Creation 5 app.
I want to try and deal with the main issues that have come up in the direct feedback to us, and also through this forum:
1.The top request has been to add the Net Radio feature – we are working as hard as we can to provide a solution for this and hope to provide this in a future release, however we do not have a date for this feature as of right now
2. Track listing in the original order – this will be provided in the next release within the next 3-4 weeks
3. Connection problems – this has been something we have only seen occur in some set-ups and we are trying to understand the cause of this – it may be the Network traffic at connection time, as in most cases this is resolved by closing the app fully and re-starting – if there are continued experiences of this can those users please contact us and we will do everything we can to help
4. Background image resolution – we can only display the cover art in the resolution it is first stored when it is tagged – the suggestion in the forum by ‘bsantini’ to use the Bliss, or similar tagging system will help – if the resolution is improved for the cover art it will look better in the background
5. The ability to go to any letter to search, has been resolved with the next release
6. We are working on how we handle the disc cover-art in the app – loading too many covers has resulted in very slow movement of the window, and the memory issue can become a problem, particularly with older iPad models – we will continue to improve this feature with updated releases
7. We are unable to provide a ‘Shut Down/Power Off’ button in our app as unfortunately this feature is not supported in the DLNA platform
8. A small number of users have had a problem with album art disappearing - we suspect this is something that can be resolved in the BeoSound 5 – we have experienced the loss of cover art where the BeoSound 5 fails to send the information – if you go to the service settings and rebuild the music server the app will get the information again.
Thank you again for your feedback, we are genuinely grateful for you taking the time to help us understand and fix issues, and also help us identify the features you would like to see added to future versions.  We will continue to offer interesting and stylish products and applications for the B&O owner, and will do our best to take all of your suggestions and implement them where possible.
claudiu
copenhagen
Posts 193
Thanks a lot for a nice app.
Can you give us some more information about the second app.?
I have lutron, mlgw can use this app.?
Regards claudiu
Razlaw
Posts 4,345
Razlaw replied on Wed, Aug 1 2012 8:01 PM
Thank you for the app, your posting here, and your efforts to improve the app.
Your other app mentions that a Masterlink Gateway is required, or another item called an MLPLNet Interface. What is that?
Creation
Posts 9
Creation replied on Fri, Aug 3 2012 12:09 AM
We are currently updating our web site with some additional information to outline the product features, as we bring the full Creation product range to the market.  The On-screen Menu is one of the key products in the Creation range and links with the ML Gateway and BeoSystem3 to provide control of the B&O and 3rd party hardware. e.g. Lutron, Kaleidescape etc.  The software provides a similar design to the Creation 5 app and retains the same focus on simplicity of operation - it can be operated using the Beo4, iPad app, our Creation Joystick controller, or the soon to be released iPhone application.  If you do not currently use the ML Gateway, we also produce a similar product - the 1ML-PL - which can also provide a link from our system to the B&O/3rd party hardware.
We are currently rolling out the product through the B&O Dealerships - if you are interesting in finding out more about our products, please provide us with your location and we can suggest a dealership that can help you understand how you can integrate our new product range with your existing B&O/3rd party set up, to provide ease of operation for the various components in your system. You can contact us directly at info@creation.com.es
BeoJunkie
Posts 16
BeoJunkie replied on Fri, Aug 3 2012 12:19 AM
I noticed if you just pause or stop eventually the BS5 will power down, however I'm surprised no mentioned Mots or just the ability to create a playlist based on one song.....
TWG
Posts 1,672
TWG replied on Fri, Aug 3 2012 11:16 AM
@creation:
 How did you test the Beosound 5 software? Only with a default Beosound 5 configuration? I can't get the software to work. It only displays "currently finding Beosound 5" and nothing more!
As written above I have renamed my Beomaster to a custom name and I have password protected the unit. Musicserver is set to ON but nothing happens!
Beosound 5 is set as slave while a Beosound 3000 is the master.
nico vercammen
Elversele, Belgium
Posts 174
The BM5 must be master in the ML network...
It can not be a slave. (this is for all DLNA apps, if you want to use  the BM5 as renderer)
I hope B&O changes this in the future
other dlna apps can use the BM5 as a media server but not as renderer when the BM is setup as slave.
I use this setup and stream the audio to an airport express. (which is connected to the aux input of a BS9000)
It would be interesting if the creation app could do the same.
Only problem is all audio goes through the ipad, so it drains the ipad  batteries, and you need a perfect wifi connection
nico
Razlaw
Posts 4,345
Razlaw replied on Sat, Aug 11 2012 1:32 PM
I see that a new version of the App was released today. It includes several new features such as Playmaker compatibility, bug fixes, etc. i am eager to try the new improved version but am traveling at present.
Razlaw
Posts 4,345
Razlaw replied on Sun, Aug 12 2012 11:21 PM
I just tried the updated App. It seems to work perfectly. Only problem I have is some albums are not receiving the cover art that exists on the Beosound 5.
It is now possible to scroll through all tracks and search by first letter.
Thank you Creation for what now seems like the App we have been waiting for you use with our Beosound 5s.
Razlaw
Posts 4,345
Razlaw replied on Sun, Aug 12 2012 11:23 PM
nico:
nico
What do you mean that the audio goes through the iPad?
I can use the App to select a piece of music, turn the iPad off completely and the music keeps playing?
nico vercammen
Elversele, Belgium
Posts 174
Razlaw:
nico:
nico
When i use another app like Twonky,  I use the ipad as player  and not the beosound5, than i push the ipads output to the airport express, so the music goes always via the ipad,
When I close the ipad, music keeps playing, but when i turn it completely off, music stops. (this is normal)
The Creation app uses the beosound5 as player but then the beosound must be audiomaster in the ML network...
When doing this you do not need the ipad running, so no battery drain, and when you are moving in the house, you will never have a drop out when the ipad is out of range from the wifi network, the ipad is just a controller
I do not understand why the beomaster5 needs to be audiomaster in the ML network to enable DNLA as server and player.
Hope B&O changes this sometimes ...
The new Creation version looks already a lot better.
Now it finds the BM5 server without it needs to be audiomaster in the ML network, but you can still not use the ipad as player
I wonder if the  playmaker is recognized as player by the app ? What do they exactly mean by "support for playmaker" ?
nico
Fisp
Denmark
Posts 75
Fisp replied on Mon, Aug 13 2012 2:13 PM
Razlaw:
Hi
This is not my experience. When Creation5 is playing in the background the music stops/pauses before the next track. Then, if I try to open the app. again, it crashes.
Creation
Posts 9
Creation replied on Mon, Aug 13 2012 5:21 PM
Just for clarification - the app cannot continue to send the information to the BeoSound 5 if the app is closed - this is as a result of the way Apple handles the applications - once the app is closed is looses connection to the BeoSound 5 and when it does it cannot send it the commands to play the next track so the system will only play the current track it is playing and then will stop.  I'm afraid at this point in time we cannot resolve this so to ensure the music continues to play it is required that the application is left open on the iPad.
We hope everyone has an improved experience with the new update - we Thank You for all of the feedback we received - and we are continuing to work on improvements to the application for future versions.
If there is anyone that is experiencing problems with the latest version, please send us an email and we will get to the bottom of the problem as quickly as possible.
The Creation Team.
beojeff
USA
Posts 2,012
beojeff replied on Mon, Aug 13 2012 8:36 PM
Creation:
The Creation Team.
Creation Team,
Would you consider adding the option to turn off the cover art slide show? It can be somewhat distracting.
TWG
Posts 1,672
TWG replied on Tue, Aug 14 2012 7:44 AM
@creation:
Do you consider releasing your application for Android? As the number of Android-Tablets is raising it would be great to use the application on Android, too!
Creation
Posts 9
Creation replied on Tue, Aug 14 2012 9:09 AM
We are looking at the layout of the background slideshow and have a few ideas for this - we will have this adapted for a future release - we will look at an option to turn off this feature - thank you for the feedback.
Creation
Posts 9
Creation replied on Tue, Aug 14 2012 9:21 AM
Our priority was to develop apps for the iOS platform, however we are currently discussing Android platform - in fact as I type there is a discussion taking place between 2 of our developers on this very topic - I don't have any timeframe for this right now but it is something we are looking into.
Maab
Posts 95
Maab replied on Thu, Aug 16 2012 2:48 AM
This question is a long shot, I know... I am wondering whether this app can be used on an iPad to control a macmini (instead of a beosound), can it be possible?
Creation
Posts 9
Creation replied on Thu, Aug 16 2012 9:51 AM
The application can recognise any device that is running DLNA - if the MacMini is running DLNA you would see it as a server and be able to see Music content on the hard drive and stream that content to any of the Renderers/Players in your network - I'm not sure if there are specific things you want to do with the MacMini - if there is something in particular you would like to do let me know and we can let you know if it's possible.
Maab
Posts 95
Maab replied on Thu, Aug 16 2012 1:29 PM
Creation:
Yes please. The reason i like to use the Mac mini is "Dirac Live room correction software" running on it. My understanding is that the Mac is, in this case, a player. Between the Mac and beolab 5s there is a converter: FireWire to spdif.
Thanks for your reply.
Fisp
Denmark
Posts 75
Fisp replied on Fri, Nov 16 2012 1:01 PM
Thanks a lot for the latest update. It works much better now and one important new feature for me is the ability to have Creation5 play in the background. This makes it much more useful.
I have a problem with the cover art. Creation 5 only shows part of the cover and cuts it off around the edges. As if zooming in on the cover. This happens to both my own covers (512X512 dpi) and the default B&O cover.
Also the extended content list is very useful. However, not all items in the list are relevant for all users and I was wondering if it might be possible to select which items to be displayed? For instance a clickable list like "Background Mode" (Nice feature, by the way)
gabriel
Norway
Posts 42
gabriel replied on Sat, Feb 7 2015 5:55 PM
Tre app is great, but it will not play my WAV songs, and many of the songs in BM 5 doesn't show up in the app. Why?
Beovision 7-55" 3D, Beosound 5, Beolab 9, Beolab 8000, Beovision 6, Beo 6, Beoremote one, H8, H2.
BeoJunkie
Posts 16
Hey guys, has anyone tried MOTS yet? That was always my problem with the app. Picking one song for continued play
Page 2 of 2 (78 items) < Previous 1 2 | RSS
