No sound from MCL2A
This post has 7 Replies | 2 Followers
dr_freudling
Posts 6
dr_freudling Posted: Sat, Jun 25 2016 10:45 PM
Hi everyone
I'm trying to set up an extra speakers kit for my BM6500. I have a problem with a relay box though.
It seems i can't get no signal from the speakers output on the box. The transceiver seems to work and i can start the radio or the cd player or whatever from it but the speakers (CX50s) remain silent. The speakers 2 out from the BM is ok, I tested that by connecting speakers directly to it. And one other setup of x-tra speakers kit does work great, so I'm guessing there is something wrong with the box.
Does anyone know what it might be?
I have very little experience from MCL2A, I am just replacing my old MCL82s along with my BM5000.
ProGram
59269 Beckum, Germany
Posts 383
ProGram replied on Sun, Jun 26 2016 6:23 AM
can you hear the relay switching on and off in your box?
dr_freudling
Posts 6
Good question!
I just tested and I hear no clicking sound when pressing the mute button as I do with the box that works.
Does this mean the relay is broken?
ProGram
Posts 383
ProGram replied on Sun, Jun 26 2016 8:43 AM
Yes, somewhere in that area. The relay can be faulty or cannot be triggered.  Do you have electronic skills?
dr_freudling
Posts 6
Not really, but you can always try me :)
ProGram
Posts 383
ProGram replied on Mon, Jun 27 2016 11:27 AM
So, what about the supply voltage for the relay? Does it change from high to low and the other way round?
dr_freudling
Posts 6
Sorry I've kept you waiting ProGram, I've not been able to check the equipment.
As I feared I couldn't figure out how to measure what you are describing but the seller of the relay box has kindly provided me with a "new" one and that one seems to be working alright.
Thank you for your time, but I probably won't be looking into this any further until I need some sound in yet another room...
ProGram
Posts 383
ProGram replied on Fri, Jul 8 2016 8:16 AM
Of course no problem. That's the easiest way.
Page 1 of 1 (8 items) | RSS
