Don't know what this is
wokbelly
Midwest USA
Posts 39
wokbelly Posted: Mon, Jun 27 2016 4:17 AM
I have a B&o serial number 08902522 Type 5103 (no model number that i can see)  that i bought with some other B&o stuff the guy i bought the stuff from didn't know for sure what it was all i know about it is it has a female din outlet with a group of 12 pins in a rectangular pattern. it also has a cord coming out with a 7 pin male din plug. the box is a 12 inch x 3 inch size box any clues to what this is?  Thanks
MediaBobNY
Greenwich Village, NYC
Posts 1,106
That's the power supply for B&O's CMM-10  CD Changer, which was actually a rebadged Sony 10-CD car changer.  Sold only in U.S. and intended to be used with the stacked Beosystem series.
wokbelly
Midwest USA
Posts 39
wokbelly replied on Mon, Jun 27 2016 5:03 AM
Thanks so the cd changer plugs into the 12 pin outlet i take it and the 7 pin goes to the receiver?
MediaBobNY
Posts 1,106
Here's an eBay auction for one.   Power supply plugs into CD changer.  7-pin DIN cable from changer plugs into receiver (usually Tape-2 input).  The power supply also facilitates remote control operation.
wokbelly
Midwest USA
Posts 39
wokbelly replied on Mon, Jun 27 2016 6:18 AM
you dont know what model sony it would be? it probably be cheaper to buy the sony version since i have the adapter already
MediaBobNY
Posts 1,106
No clue.  I'd sell you mine but I'd have to include the power supply since it's useless by itself.  Send me a PM if interested.
wokbelly
Midwest USA
Posts 39
wokbelly Sad [:(] replied on Tue, Jun 28 2016 11:07 AM
Sad  I tried to send you a pm i think but it failed i got a delivery failure
MediaBobNY
Posts 1,106
'Got a bounceback on the one I sent to you as well.  Send an email directly to me at mediabobny1@aol.com.
Page 1 of 1 (8 items) | RSS
