Is BeoLab 3500 still any good?
This post has 10 Replies | 2 Followers
Beoberg
Odense, Denmark
Posts 315
Beoberg Posted: Tue, Jun 28 2016 11:13 AM
I am moving from my appartment to a house this summer and because there are more rooms, I am now considering adding some new B&O equipment. I am thinking about getting a BeoLab 3500 (second hand) to connect with my BeoSound/BeoMaster 5 for the dining room. I have never actually heard the Lab 3500 playing and I am curious of how you guys think it is holding up today? Any inputs would be much appreciated Yes - thumbs up
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Jun 28 2016 11:55 AM
I had a Beolab 3500 in my library for a couple of years.
Sound is very pleasant, and surprisingly full. Played much jazz-type of music an really enjoyed it.
Make sure you get a fresh one with foamrings in good shape.
I have later replaced the BL3500 with a Beoplay A6.
/C
elephant
AU
Posts 8,219
elephant replied on Tue, Jun 28 2016 11:56 AM
The BL3500's specs are comparable to the BL6000 if that helps
BeoNut since '75
olvisab
Posts 1,391
olvisab replied on Tue, Jun 28 2016 12:30 PM
Hi
if you set bass and treble to a good level, this speaker rocks.
best speaker on wall for a kitchen or any room where space is needed.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Beoberg,
Yes, this is a nice speaker and sounds good in small to medium sized rooms.  As well as a Masterlink input from the Beomaster 5, you can also add a direct connection from an portable device such as an iPod, which helps to make this speaker even more versatile:-
http://soundsheavenly.com/airport-express/155-ipodtvairport-express-to-beolab-3500-mk2-cable.html
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Seanie_230
UK
Posts 2,278
Hello all
I have a question without aiming to take over the thread.
Can a BL3500 be run as an independant speaker perhaps connected to an essence MK2 that has IR.
Does it automatically turn on and off when powerlink feed is detected?
I like the idea to buy a 3500 and Essence MK2 with IR over the Beosound 35
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Jun 28 2016 3:25 PM
Seanie_230:
Hello all
I'm quite sure it needs eg a NL/ML converter and a powerbox to function with an Essence
Posts 2,165
Seanie_230:
Hello all
Hello Seanie_230,
Yes, you can make a direct connection from an Essence to a Beolab 3500, however you would need to control the Essence via the smart phone app or the bluetooth remote, as using the IR remote would switch off the Beolab 3500 (a direct connection relies on opening the MCL or Powerlink port on the 3500, which has to be done via an IR remote command).
If this option is of interest, please drop me a line via the forum or my website and I will be pleased to help you get this set up.
Steve.
Beoberg
Odense, Denmark
Posts 315
Beoberg replied on Wed, Jun 29 2016 8:49 AM
Hello fellows,
Thank you very much for your inputs. I am going to pick up a BeoLab 3500 from 2004 on monday. Got it at a steal (£160!) Looking forward to hearing it.
Best regards,
Frederik
Teletom
Posts 27
Teletom replied on Wed, Jun 29 2016 6:01 PM
Hiort:
......I have later replaced the BL3500 with a Beoplay A6.
/C
Hi Hiort,
I' am also considering to replace my BL3500 mk2 with a A6.
Would like to know your opinion if the A6 sounds (much) better than the 3500.
Thanks in advance.
Teletom
Teletom
Posts 27
Teletom replied on Thu, Jun 30 2016 3:52 PM
Hi Hiort, I'am (also) thinking of replacing my BL3500 mk2 with a Beoplay A6. Before doing so, I would like to know if the A6 is a better system than the lab 3500 soundwise.
Thanks in advance, Teletom
Page 1 of 1 (11 items) | RSS
