Does anyone know if you can mount a Beovision 7 55 on a Beovision 7 40 motorised floor stand?
Yes, I know,- its not possible!
For starters the width of BV 7-55 attachment is roughly 25% wider!
Thanks. That is a change in my plan then.
You are hopefully not giving up on getting a BV7-55 :-)
