LC2 Not Working?
This post has 10 Replies | 1 Follower
moreton
Posts 42
moreton Posted: Sat, Jul 2 2016 6:25 PM
Hello,
I bought an lc2 from someone a while ago and have only just got around to installing it.
The bloke I bought it from said he bought it as working perfectly but he didn't have a Beolink 1000 to set it up (???) and never got around to getting one etc etc etc, and so sold it to me as untested.
I'd bought a few other bits from him with no problem so I had no reason to doubt him, anyway, I've just installed it and nothing is happening either by hand or by Beolink1000 or Beo4.
I've tried changing the little fuse in it but no joy.
Does anyone have any ideas before it goes on eBay for parts?
Thank you,
David
leosgonewild
Helsinki, Finland
Posts 2,373
Have you tried resetting it?
moreton
Posts 42
moreton replied on Mon, Jul 4 2016 1:00 PM
Ah, no, I didn't know there was a reset. Do you know how to do it?
thanks,
David
leosgonewild
Helsinki, Finland
Posts 2,373
I think you hold the black plastic while pressing
LIGHT, GOTO, 0, STORE, 2
Not sure. Found it in the forum.
leosgonewild
Helsinki, Finland
Posts 2,373
Or this
Light, Goto,0,Store,4
Millemissen
Flensborg, Denmark
Posts 14,680
'Resetting'?
I have always thought, that a new setting would overwrite an older one.
If, so - no resetting needed.
moreton
Posts 42
moreton replied on Mon, Jul 4 2016 1:41 PM
No, no joy unfortunately.
I don't have a goto on my Beo4 but I remember reading that scrolling to lamp under light and pressing go, would do the trick.
Maybe it's just a duff one after all?
stefan
200 miles from Struer
Posts 2,920
stefan replied on Mon, Jul 4 2016 2:17 PM
moreton:
... but I remember reading that scrolling to lamp under light and pressing go, would do the trick.
That`s nonsense. LIGHT - GO or LIGHT - PLAY (depends on your Beo4) should activate your lamp.
- Which lamp did you connect?
- Is it 220-240V?
- did you connect the +/- wires correctly - on both ends?
- Does it work when you touch the black dome?
- Did you read the setup manual?
Stefan
moreton
Posts 42
moreton replied on Mon, Jul 4 2016 5:58 PM
Hi Stefan,
I did wonder, so I tried as you suggested - no joy unfortunately.
It's a 220/240v lamp and I've double checked the wiring and changed the fuse in the lc2 and the plug.  I've tried the dome and the Beo4, it doesn't work with either, and I've gone over and over the manual and done everything correcty as far as I can see.
I spoke to the B&O engineer to see if any spare domes are available, needless to say there was no joy the either.
Oh well, it's annoying but not the end of the world - thank you for the advice though.
David
marexy
Posts 710
marexy replied on Mon, Feb 27 2017 6:58 PM
Hi
Anyone have shematics-service paln for BOSSCOM  UnoDim 300/LCR Dimmer  please?
I have broken one and want to fix it :(
like that :
http://www.cb-leipzig.de/Produkte/Lichtsteuerung/Unotech/unotech.html
UnoDim300/LCR
marexy
Posts 710
marexy replied on Mon, Mar 13 2017 9:00 AM
It's like LC2 dimmer
How-where , can i find service manual ( PCB spec. ) ?
Page 1 of 1 (11 items) | RSS
