Beolab 5000 amp power on and off with no reasons
olvisab
Posts 1,391
olvisab Posted: Sun, Jul 3 2016 7:03 PM
hi
I have beolab 5000 on wall that power on and off without any reasons. Most of the time it is only one speakers and sometimes both at the same time.
These speakers are plugged on a bv 7 as center speaker with a beolab 10. The beolab 10 still works when the beolab 5000 stop working. They stops only a second.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
stefan
200 miles from Struer
Posts 2,920
stefan replied on Mon, Jul 4 2016 2:24 PM
So you have three center speakers connected to your BV7?....
BL10 will be activated via PIN4 on Powerlink - BL5000 need PIN1.
Did you connect an adapter?
Same behaviour when you assign BL10 to center and BL5000 to front L/R?
Stefan
olvisab
Posts 1,391
olvisab replied on Mon, Jul 4 2016 9:52 PM
Hi stefan,
thanks for your answer.
not exactly 3 center speaker
For tv viewing I use the beolab 5000 as front and beolab 10 as center.
this problem happens most of time when I watch tv (beolab 5000 as front and beolab 10 as center).
for 5.1, I use the beolab 5000 with the beolab 10 as center speakers. For the front I have 2 beolab 5.
everything worked perfectly during several years. Now this problems occurs suddenly.
the beolab 5000 that has this issue is the one where the second beolab 5000 is connected (by powerlink).
Page 1 of 1 (3 items) | RSS
