Beomaster 1200, Supply Voltage.
Jamian
OREGON, USA
Posts 33
Jamian Posted: Sun, Jul 3 2016 9:32 PM
Hi
Recapped my BM1200 (Dillen’s kit). It works but there are some challenges I need help with.  Here is the first -
Supply Voltage (33V target)
Input is set to 110 (USA).  Am I taking the reading correctly?  If so what could be the challenge?
1. What I though I should be doing: Attach the multimeter (DC auto) to 456 and ground off the power supply board = I get 55V and it does not change as I adjust 459.
2. Tried connecting to the neutral: Attaching to 456 and the neutral line  = I get 28V, which does not change as I adjust 459.
3. Tried connecting to the 455 resistor the other side of 459 = The voltage changes (16-23V)as I adjust 459, but can not get 33V.
4. Just out of curiosity I attached across 456 and 459 = Voltage changes as I adjust 459. I can get 33V.  But, do not believe this is in any way what I am trying to accomplish.
I continued to set the no-signal currents anyway, which I could get to 7.5mV.  The unit plays an external input through Tape (slight hum as volume turned up, with no input), but of course I want to sort out the supply voltage challenge.
I took a reading off my BM1001 (which I have been using for a long time, input set to 110) and it is more like 4-5V at 456?!?  I have never opened this one up before as it has never shown any issues.  Thought it might be useful to compare.
Stuck!
Cheers.
Love = My  Beomaster 1001 + Beovox 2700
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Jul 3 2016 10:05 PM
Keep in mind, that the negative pin of the large filter capacitor is NOT ground.
Jamian
OREGON, USA
Posts 33
Jamian replied on Sun, Jul 3 2016 11:51 PM
Hi Dillen
Here is a picture of my #1 attempt, which is what I thought I needed to do:
Page 1 of 1 (3 items) | RSS
