BEOGRAM TX - Slow In/Out Buttons
MRL_TX
Posts 8
MRL_TX Posted: Mon, Jul 4 2016 8:02 PM
First-new here and happy to now be a member after lurking for some time.  After some research here I decided on a TX.  Everything appears to work as expected across all buttons and functions net of one.  The buttons for "slow" inwards < and "slow" outwards > do not seem to respond.  The use of the two, inner and outer tone arm "slow" movement buttons provide little reaction by the arm.  If I press either one with the table and tone arm in Play the arm will lift but does not move. Same behavior with either button. If however I press the standard/"fast" <<, >> tone arm movement buttons they work as they should.  Any thoughts or help appreciated.  Thanks for the time and expertise.
  • Filed under:
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Jul 4 2016 9:50 PM
Most likely a matter of cleaning and lubricating the threaded shaft and the carriage rails.
With only a very small electric current, the servo motor will not be able to move the carriage, if the mech. is not running smooth.
MRL_TX
Posts 8
MRL_TX replied on Tue, Jul 5 2016 5:11 PM
Thanks for the reply.  I've cleaned what is visible to me at this point.  Perhaps a disassembly is needed to clean it properly.
Page 1 of 1 (3 items) | RSS
