BEOGRAMM 7000 stops
Svante64
Posts 4
Svante64 Posted: Wed, Jul 25 2012 2:41 PM
Hi guys,
can't figure it out on my own, mybe somebody has a clue: the obove mentioned turntable stops just seconds after I push the play button. What appears to be the problem?
Does it sound like a small problem worth checking or is the whole thing just crap?
Svante64
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
It won't play unless you have placed a record on the turntable!!
Regards Graham
Mindphaser
Posts 100
Unfortunately i cannot suggest an answer since i don't have any Beogram;
but even if it's broke (which i don't think BTW) i would buy it (no joking :) )
The msot beautiful turntable EVER made IMHO.
ClausMikkelsen
Posts 26
Svante64:
Turntable stops just seconds after I push the play button. What appears to be the problem?
Hi Svante64,
I bought a used Beogram 7000 record desk a few years ago and it had the exact same problem. Even with a record on, the Beogram would only turn for a second or two, then stop again. In my case, it didn't cost me very much. It didn't require new parts, but just an adjustment by the technician. Big Smile
Regards
Claus (Denmark)
Svante64
Posts 4
Svante64 replied on Wed, Jul 25 2012 7:10 PM
Thanks Graham,
I placed a record on the turntable...
Best,  Lasse
Svante64
Posts 4
Svante64 replied on Wed, Jul 25 2012 7:12 PM
hej Claus,
tack för den uppgiften, då ska jag kolla med B&O om det här.
Hälsn. Lasse
Svante64
Posts 4
Svante64 replied on Wed, Jul 25 2012 7:13 PM
:-) It's not mine....
Page 1 of 1 (7 items) | RSS
