beolink 1000 remote battery acid?
Taylor T
Southlake Tx
Posts 26
Taylor T Posted: Fri, Mar 2 2012 10:12 AM
I have a beolink 1000 remote and it works fine for about 4 days but always leaks batt acid iv cleaned it put new batts in but nothing i do keeps it from causing the new batts to leak acid any ideas im lost on this one any help much appreciated
Beosystem 4500 With Beogram rx2
Beomaster & Beocord 3300
Beocenter 9000
Beosound 2000
Beolab 6000
Rl 140 & Rl 35
Beovox S75
Step1
Manchester, UK
Posts 1,268
Step1 replied on Fri, Mar 2 2012 2:29 PM
Have you fully stripped the control down as far as it will go? Sounds like it is draining the batteries which will likely cause them to leak...
Olly
MediaBobNY
Greenwich Village, NYC
Posts 1,106
Seems to be a common problem with 1000's, but not Beo4's.  Wonder why.
Taylor T
Southlake Tx
Posts 26
Taylor T replied on Fri, Mar 2 2012 11:50 PM
i took it fully apart a few months ago going to try and do it again tonight see if i can see anything i missed.
Beocenter 9000
Beosound 2000
Beolab 6000
Rl 140 & Rl 35
Beovox S75
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
