New speaker connection and cabling standard
This post has 2 Replies | 2 Followers
Mico
Finland
Posts 13
Mico Posted: Wed, Jul 25 2012 7:22 PM
hello everybody,
It seems that B&O is changing connection standard from DIN (Powerlink) to RJ45. I am a little puzzled about cabling. Can I use CAT5 cables for a connection (for example Playmaker to BL12) or do I have to use CAT7 and can I use ordinary CAT7 cables available from Computer stores or do they have to carry a B&O label???
wesheltonj
Texas
Posts 22
Cat5 -not really, its not shielded.
Of course the Beonet guide says use B&O cables or Scheinder.  IMO I do not think it makes a differance as long as its really CAT7.  By the way, you might be better off with CAT7a as faster data transfer rate should you need that function.
BeoSystem 5500, BeoVision 10-46, BeoLab 8002
Apple TV
Samsung BD-D7500
Wii
Heribert
Vorarlberg / Austria
Posts 804
Heribert replied on Fri, Jul 27 2012 10:16 AM
I am using Cat5e, Cat6 and also CAT7 lines in my Masterlink setup without problems. I believe CAT7 is just needed for Video and not so important for Audio.
BV 11-46  / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Page 1 of 1 (3 items) | RSS
