Beomaster 5000 speaker outputs
This post has 3 Replies | 2 Followers
roulezcool
Posts 3
roulezcool Posted: Fri, Jul 8 2016 1:00 PM
Hi
I have a Beomaster 5000 amplifier and Beogram 5000 turntable but no speakers. I had intended to make some 2 pin din to RCA cables for my active speakers but reading through the forums i understand this is not a possibility,
What are my options? should i try and locate some old B&O speakers? How do they compare against  todays speakers.
I would prefer to use my active speakers. is there anyway of connecting them?
On the back there is an rca pre amp connector. I tried to connect that to another preamp but the sound was almost inaudible (i'm not even sure if the connector is for that purpose)
Any help greatly appreciated
AdamS
Posts 373
AdamS replied on Fri, Jul 8 2016 1:07 PM
If you have active speakers then just plug them straight into the RCA preamp out sockets and this will work fine. The reason you had low volume when you connected them to another preamplifier is that they are meant to drive a power amplifier (or active speakers!).
Of course you should really be using a pair of Pentas with this system, IMHO, but they can come later!
roulezcool
Posts 3
Thank you Adam for the quick reply and for sorting out the problem. Its great to hear my old vinyls again. I will look into Pentas. Have a great day
roulezcool
Posts 3
Page 1 of 1 (4 items) | RSS
