Beomaster 4400 something else to learn
This post has 128 Replies | 3 Followers
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
found the mounting clips a little tricky to align during this task, I very small amount of washing up liquid on the plastic tangs made the job much easier and they popped back in with very little force.
Craig
Posts 2,040
Silver Member
I'm pleased with the way this is coming along.....there remains a lot of components still to replace but I have yet to find any issues.
Craig
Posts 2,040
Silver Member
having replaced all the presets, well all the ones I could find...I decided to start at the right hand side and work left changing capacitors as I go.
Craig
Posts 2,040
Silver Member
still a fair way to go......should I replace the rectifiers too while I have this apart?
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Aug 8 2016 8:41 PM
Let me know when you are back and we can sort something out. What speakers are you planning on using?
Peter
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Aug 8 2016 10:00 PM
Craig:
No. Why?
Craig
Posts 2,040
Silver Member
Craig replied on Tue, Aug 9 2016 8:08 PM
Cheers Peter, much appreciated, I will be using a pair of beovox 3800's I recently restored (well re capped the crossovers) .........now back to the beach ;-)
Craig
Peter
Earsdon
Posts 11,991
Peter replied on Fri, Aug 12 2016 9:39 PM
If you would like to borrow some M100s at the same time, my wife would no doubt be delighted! They may need the overload circuit playing with but that normally means some emery paper! I might ask you to look at a Beogram 4001 (!) which needs a little work!
Peter
Craig
Posts 2,040
Silver Member
Well......back from doing this! 2 weeks was not long enough. Will get back to the 4400 this week and crack on with the recap, Peter you certainly have an Aladdin's cave full of quality equipment I have to say ;¬)
Peter
Earsdon
Posts 11,991
Peter replied on Tue, Aug 23 2016 10:02 AM
I am on holiday the next two weeks but apart from a wedding in Norwich, I am at home - I could actually bring the bits down next week if that was convenient - do you want to borrow the M100s? They are rather large! I take it you have S45-2s?
The Aladdin's cave is actually rather sparse these days - I used to have a lot but these days I have very little - I do have a 6000 quad - do you want to play with that? It is somewhere under the bed!!Big Smile
Peter
Craig
Posts 2,040
Silver Member
Craig replied on Tue, Aug 23 2016 12:58 PM
Peter
I will be home all of next week, the M100's are very large your quite right...I have 3800's myself which should be fine. Regarding the Beogram 4001 I would be happy to take a look...bear in mind my experience with B&O is limited to that which I have chronicled on this site ;¬)
Craig
Peter
Earsdon
Posts 11,991
Peter replied on Tue, Aug 23 2016 9:04 PM
I have used 3800s with a 4400 and they are super speakers - I have re-homed a pair in the past. I'll contact you once back from Norfolk - if without speakers, it might be an excuse to give the Triumph a little run if only to test the new water pump I plan to fit!
Peter
Craig
Posts 2,040
Silver Member
Craig replied on Wed, Aug 24 2016 7:38 AM
Peter
Sounds like a little 2 seater to me? I wouldn't need an excuse to have a run out with the top down while the weather holds ;¬)
Craig
Posts 2,040
Silver Member
Getting there.....all caps now replaced, time to start rebuilding
Craig
Posts 2,040
Silver Member
don't know what happened to the last pic.....came out like a salvidor dali
Craig
Posts 2,040
Silver Member
Going back to the power supply connector, I came across this on ebay......
Craig
Posts 2,040
Silver Member
still had to identify live and neutral on the cable but as everything is still in bits that was easy
Craig
Posts 2,040
Silver Member
taking shape........next step, power up and consult Rudi's blog to set up the idle current. I know I should tie in a DBT for the initial power up just in case but I don't have one.......tough decision.
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Aug 29 2016 1:00 PM
Craig:
Oh, very nice contraption this, great find and new to me!
And boy do your sliders look good with their green lines Yes - thumbs up
Jacques
Craig
Posts 2,040
Silver Member
In accordance with the teachings of the grand master........
Craig
Posts 2,040
Silver Member
and the other side.........
Craig
Posts 2,040
Silver Member
Craig replied on Thu, Sep 1 2016 7:42 AM
Still got these water spots on the case......tried to clean them off but no joy, was thinking maybe a light application of teak oil may do it.......anyone got any ideas?
Craig
Posts 2,040
Silver Member
Im also missing a preset cover......if anyone knows where such a thing is available (just to finish things off) Dillen?
Dillen
Posts 13,191
Dillen replied on Thu, Sep 1 2016 9:47 AM
The preset cover: http://archivedforum2.beoworld.org/forums/t/11520.aspx
If you are measuring across BOTH emitter resistors, 5,5mV is not enough for a correct idle current.
5,5mV across ONE or 11mV across BOTH.
Craig
Posts 2,040
Silver Member
Craig replied on Thu, Sep 1 2016 12:51 PM
Thanks for that....I have sent a paypal payment for one off cover, will look great. I will also double check the connection points I used on the 2W resistors for the 5.5mv adjustments....I'm pretty sure I was only across one resistor (went from the top of each vertically installed component) but I will certainly make sure of this...thanks ;¬)
Craig
Craig
Posts 2,040
Silver Member
finished up.....light application of teak oil has removed the water spots nicely
Craig
Posts 2,040
Silver Member
last one before connecting up to some speakers and Spotify
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Sep 2 2016 4:06 PM
Job done!
Congratulations and happy listening. Most definitely one of the very best receivers on the market, even today. And powerful too!
The teak oil is also what I use for water marks, but you'll have to do it again from time to time.
Smile
Jacques
Søren Mexico
Mexico City
Posts 6,411
Like new Craig, compliments
Here is mine during last tests, it is still working hard every day with my M70s now 3 years.
the_o_master
Posts 856
Craig:
Very nice job!
And I noticed one more difference: the markers on the sliders are green instead of red Smile
I like this receiver lot...
Theomaster
Vintage Bang & Olufsen
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Sep 3 2016 7:54 AM
Søren Mexico:
Same here, M70s, used daily for several years.
Hi Søren! How are you?
Jacques
Søren Mexico
Mexico City
Posts 6,411
chartz:
Nearly back to normal Jacques, How are you
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Sep 3 2016 7:28 PM
Søren Mexico:
chartz:
Nearly back to normal Jacques, how are you?
I have had some persistent, unexplained cough for two and a half months. I don't smoke. Not so good then. Sad
Jacques
Craig
Posts 2,040
Silver Member
Craig replied on Sun, Sep 4 2016 4:21 PM
Jacques.........don't ignore this, go and consult a sawbones and get some tests, early detection of anything has to be the way forward
Søren Mexico
Mexico City
Posts 6,411
Craig:
Agree with Craig, and bring your own scope when testing Smile
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Sep 4 2016 6:04 PM
Craig:
I will, promise.
Jacques
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Sep 4 2016 8:15 PM
You need a Chest X-Ray - you should be able to get it done in 24 hours. Better still would be a CT scan.
Peter
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Sep 4 2016 8:17 PM
Not managed to find time to get to Yarm - and not sure when I can find time!! I will however get it ready.
Peter
Craig
Posts 2,040
Silver Member
Craig replied on Sun, Oct 9 2016 2:22 PM
well......just when everything was going fine!
Received two more Beovox 3800 speakers which where in very poor shape....one cabinet had all the speakers hanging loose due to missing screws and damaged housing. Got them sorted and recapped before connecting up to the BM4400, all was fine and I enjoyed a period of just enjoying the 4400 connected up to two sets of Beovox 3800's and was considering another project when yesterday the 4400 suddenly fell silent half way through Billy Joel's Piano man! Unwilling to blame Billy I decided to open her up. on inspection the overload relay RL 1  looks like its kicking in immediately on power up.....further inspection revealed that the left channel output transistors  IOC 100 & IOC 101 where loose against the heat sink, this was not a chance discovery as I had been fiddling with the heat sink screws from the outside the day before and didn't know they held the above in place (clearly a schoolboy error there) and I fear the worst as a result. Re securing the transistors has not resolved the issue.
So its the circuit diagrams this afternoon, any guidance on this would be appreciated whilst I ponder the diagram?
Craig
Posts 2,040
Silver Member
Following on my take on this is that the fault switch has been activated by failure of IOC 100 & IOC 102. My understanding of this protection is if a high temperature is sensed at the heat sink by PTC R40 its resistance increases turning on IC3 and energising R1 which isolates the 35v power rail. As my transistors where not fully in contact with the heat sink I feel int unlikely that this occured, I think the temperature has ran away and they have turned on TR16 as shown in the annotated diagram, double click to see notes..........
Page 2 of 4 (129 items) < Previous 1 2 3 4 Next > | RSS
