I found the downloadlink for ct6.84
www.mediafire.com/download/6s2l3qs88zqz9x1/CTSetup_6.84.exe
i have download it but it ask me username password
You must make a hook near "work offline"
oke but how must i connect with my beo6 to load de file in it
You need an USB cable to connect the docking station with your PC. Then you can load the files in your Beo 6.
Anyone exept me who has probems to login? I recently downloaded CT6.84 and cannot log in anymore. The work offline box is naturally ticked and I did not encounter this problem with the previous versionofthe CT.
Best regards,
Emil
It was mentioned in one of the topics before (cannot find fast), so it is known feature.
https://beointegration.wordpress.com/
1:BV7+BL7.1+BS4+BL6000+BV6+BL2000+MLGW+Beo4
2:BV7+BL7.4+BL3500+BM5+BL3+Lutron GE/Sivoia QS+HikVision+Dune+LinTronic+BLGW+Beo4+Beo5+Essence remote+BeoTime+BeoLinkPC+BL4+KNX+... BeoMaster900
Emil:Anyone exept me who has probems to login? I recently downloaded CT6.84 and cannot log in anymore. The work offline box is naturally ticked and I did not encounter this problem with the previous versionofthe CT.
You don't login because you don't have an account.
Regards Keith....
On which Windows version this tool can run?
