Cleaning the Beocord 5500 cassette deck
retrorod
Posts 7
retrorod Posted: Tue, Jul 12 2016 8:02 AM
2nd post after a good start here.
The good news is that I have a user manual after all (just look Rod !!)  Laughing
I use isopropyl to clean heads and tap paths (not pinch rollers)  on the R to R, however B & O warn against this product on their machines Confused
So what do owners use on their cassette decks to clean the recording and PB heads?
I'm very curious now. Big Smile
Thank you.  Rod G
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Jul 12 2016 11:50 AM
Isopropyl.
retrorod
Posts 7
retrorod replied on Tue, Jul 12 2016 12:23 PM
Thank you Martin.
Rationally I could not see why not to use it.  Rod G
Dillen
Posts 13,191
Dillen replied on Tue, Jul 12 2016 1:12 PM
The problem is, I think, that if you really soak the thing in it, it will eventually attack the rubber parts (pressure roller etc.), the parts
can swell and/or dry out.
Some tapeheads contain certain plastics, that can also be attacked.
I have always used isopropanol.
Wipe wet, then wipe dry using cotton buds. Never had any problems with that.
retrorod
Posts 7
retrorod replied on Tue, Jul 12 2016 2:31 PM
Dillen:
Yep, I'd agree with your comments.  I use hot detergent water to clean rubber parts with a cotton bud.  Looking at the recessed transport system, I'm inclined to lift the lid to give it its first clean since who knows when.  I guess I will see the belt drive also if it uses belts.
I live in Oz martin where B & O had a an excellent reputation, but the average guy found them out of their price range here,  and so essentially opted for the cheaper Jap brands.  If a belt was required, are there reliable vendors of these abroad?
Thank you again.  Rod G
Dillen
Posts 13,191
Dillen replied on Tue, Jul 12 2016 4:11 PM
I can supply belts.
MediaBobNY
Greenwich Village, NYC
Posts 1,106
retrorod:
I'm very anal about cleaning the tape heads and other bits since it makes such an audible difference in the sound quality.  I use the above-mentioned Q-Tip dampened with IP in addition to one of these.  I figure that one method cleans what the other method misses.
Page 1 of 1 (7 items) | RSS
