Playmaker, direct connection or through audio master
This post has 1 Reply | 2 Followers
Andrew
Frinton, UK
Posts 917
Andrew Posted: Tue, Jul 12 2016 1:08 PM
Hi, my playmaker is connected to my BM6500 via tape input .
Before I try and get to all the wires which go behind a cabinet, I wondered if anyone had noticed any differences if the playmaker is directly connected to the speakers instead of the beomaster. Is I clearer or better sound, speakers are BL2 and BL8000's. If there is no difference then I will leave it all as it is.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Andrew,
As long as you turn up the volume on the PlayMaker (so that it matches the level of your other music sources, eg. CD, radio, etc) then the quality should be just as good connecting via the Beomaster compared to connecting directly to the speakers.
This cable will connect the PlayMaker (or an Essence or Moment) to the CD or Tape inputs on the Beomaster 6500:-
http://soundsheavenly.com/playmaker-and-essence-wireless-streaming/84-rj45-to-aux-input-cable-airplay-on-your-bo-system.html
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (2 items) | RSS
