I recently got the Beolab 2 to give a little more punch to my set up with the classic Beosound 9000 and a pair of Beolab 8000. At lower volumes I love this combination! My issue is at higher volumes:
There seems to be some leakages around the connection panel at the back. The seal for the speaker itself and the slaves on the sides seems good, so I'm pretty sure it's only on the back. What this does is that it makes a noise similar to a badly ported sub. A loud flapping noise if you will. The back panel looks to maybe be a bit out of place, where the lower part is positioned a bit deeper than the top part (which is flush with the aluminium case).
Appart from this, everything seems fine with the sub. Unfortunately, for different reasons, I can't return the speaker.
To my questions:
1. Has anyone had the same problem?
2. Does anyone have any experience with disassembling the Beolab 2?
3. Would it be sufficient to seal this with superglue or similar from the outside?
If you didn't guess it, I'd like to go one of two ways. Either I'd like to take this appart and try to reposition the connections. If disassembly is really tricky I'd add som seal of some kind just to be sure, otherwise I'd like to try if repositioning is sufficient for the problem. The other way, if disassembly seems like rocket-sciense or if the risk of breaking something for real is to big, maybe I could try to seal it from the outside.
I'm a novice when it comes to stripping things down, but I found the BeoLab 2 pretty straightforward.. You will almost certainly have a misaligned seal at the rear, which can be rectified if you take the sub apart and have a look. It'll be seal - and the sub will have been apart before and reassembled incorrectly, hence the 'flatulent' noise you hear!
The service manuals are here on BeoWorld, I'm sure - and the only tips I would have are to keep separate areas for all the screws and components!
Good Luck
SOLVED (I think)
Turns out it was worse than I thought. It wasn't just that the connection-panel / main board was mounted wrong, the back seal / gasket was missing entirely. Considering the worn screws and sloppy cable management, my guess is that the previous owner is some lazy guy / girl who opened this up for some reason, and didn't bother to put it back together properly. "Left over gasket when all is put back together - guess I'm selling".
The good news is that I think I have fixed it. At least for the volumes I can play at in an apartment. I added some pictures of the process, unfortunately they are quite bad i realise now. The beolab 2 is incredibly well built and everything snaps together with just a couple of mm margin. I followed the repair guide I found when googling. Basically:
I hope the above can be of use for anyone trying to open the Beolab 2 for any reason (changing fuses or whatever).
