BeoSound 3200 pin code issue need help!!! TheRed LED not blinking!!
This post has 18 Replies | 1 Follower
alvern
Posts 14
alvern Posted: Sat, Jul 16 2016 10:31 AM
Last night we had a power outage in my place.Normally my Beosound 3200 Red LED had blinked after the power disconnection for more than 10 mins and then it asked PIN-code, then i do enter my 4 digit pin-code. But today its did not allowed me to enter the pin-code. The red LED only illuminates for now but no  red light flushing???
My Beosound 3200 doesn't react for no one keys of its front panel except the "LOAD" button.
I think my Beosound 3200 locked Off!!!
How can I enter my own PIN-code or reset it? Please help!!
Thanks in advance!
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Jul 16 2016 10:06 PM
Hi Alvern
Welcome to BeoWorld.
I suggest you power off the BeoSound 3200 for a few minutes then power it on again and select a source. That should hopefully prompt you to enter the PIN. If it doesn't, you may need an engineer to look at it.
Good luck
Opman
alvern
Posts 14
alvern replied on Sun, Jul 17 2016 2:16 AM
I did that already no luck, any over ideas ? what is my BS 3200 been locked?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Sun, Jul 17 2016 2:13 PM
You probably would have noticed if you entered the pincde wrong. It would have asked again after the first attempt.
Did the BS3200 start after entering the pincode?. Are there any other (pincode) protected devices connected by ML?
alvern
Posts 14
alvern replied on Sun, Jul 17 2016 3:00 PM
No pin-code devices connected by ML, The red light not blinking and all the buttons not responding  on BS 3200 ,only the load button works. can not even type the pin code, I think its super strange ?  I think the unit got locked???? Please help!!!, I need my BS 3200 start working again!!!
Beobuddy
Posts 3,972
Beobuddy replied on Sun, Jul 17 2016 4:43 PM
Try to program a  A-Option. A-opt 0,1 or 2. It should be set in Aopt1. Does the led blinks after an option-setting?
alvern
Posts 14
alvern replied on Sun, Jul 17 2016 5:15 PM
A-Option 1
Beobuddy
Posts 3,972
Beobuddy replied on Sun, Jul 17 2016 6:42 PM
Does it blink when programming? With what numbers does your serialnumber start? With 15xxxx?
alvern
Posts 14
alvern replied on Sun, Jul 17 2016 7:09 PM
I did not try programming, just check the option using test mode TM 34: Read-out of options , my serial starts 180...
CasperI
Posts 93
CasperI replied on Sun, Jul 17 2016 7:24 PM
This problem sounds a lot like a known issue with the power supply. You might need to contact your local dealer.
alvern
Posts 14
alvern replied on Sun, Jul 17 2016 7:41 PM
issue with the power supply ?? Can you be more specific please.
CasperI
Posts 93
CasperI replied on Sun, Jul 17 2016 7:53 PM
alvern:
There is a small fuse that causes this kind af failure if blown.
It is not one of those large psysical glass ones, though.
alvern
Posts 14
alvern replied on Sun, Jul 17 2016 8:09 PM
Small fuse?? its sounds like a super fast fix. Do you by any chance tell me the part number.
I hope its not too expensive part anyway.
alvern
Posts 14
alvern replied on Sun, Jul 17 2016 8:25 PM
I can call bang olufsen tech support to order that fuse
alvern
Posts 14
alvern replied on Sun, Jul 17 2016 8:50 PM
HI Casper,
If by any chance you do not know the part number, may be you know the Type or Description of the power supply fuse.
Please reply with some info if you can.
Thank you so much for all your help
alvern
Posts 14
alvern replied on Wed, Jul 20 2016 1:55 PM
Hi Beobuddy,
I have a error message on my Beosound 3200. How you  can  fix that?
19: TP module HW error APOS   My BS 3200 not responding. only load button works.
Can you  fix that?
alvern
Posts 14
alvern replied on Wed, Jul 20 2016 1:56 PM
Hi Beobuddy,
I have a same error message on my Beosound 3200. How you  can  fix that?
Can you  fix that?
alvern
Posts 14
alvern replied on Wed, Jul 20 2016 2:14 PM
I just found out that I do have an error in testing mode on my BS 3200
19: TP module HW error APOS  I think its a microprocessor issue??
Is it possible to fix?
marexy
Posts 710
marexy replied on Wed, Jul 20 2016 2:27 PM
a looooot  of BS 2300 and 3000 have the same issue.
i have one BS 3000 at home like that.
so..anyone have fix these error without B&O service ??
Page 1 of 1 (19 items) | RSS
