MCL 2P Convert to Manual Power Up
StuckInBulgaria
Posts 25
Silver Member
StuckInBulgaria Posted: Thu, Jul 21 2016 10:39 AM
First Im new to this forum and I want to express my appreciation in advance, of any and all help I may receive - it really is kind of anyone to give there time and knowledge freely, thank you to all who do!
I have just started collecting 70's B&O Equipment but ended up with a MCL 2P along the way.  Obviously "out of the box" this is of no use to me - i need to trigger the auto on.
Now as far as I can find out this is a Voltage on pin 4 of + 2.5v - 5v and - to Ground on pin 7.  I have applied 4.5v from a pack of 3 x AAA (new) with no joy.
All internal fuses are checked as OK.  There is no obvious internal re-wiring. But I get zero in terms of output. I take it this means it is not powering up BUT...I must point out the led is permanently lit red, I can not find if this is the "ON" or "Standby" mode.
Q) Does the red led indicate on or off?
Q) Is my pin data (2.5-5V P4/P7) correct?
Q) Is it going in the recycling bin?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Thu, Jul 21 2016 11:09 AM
StuckInBulgaria:
Yes. Red means off, green menas obvious on
Try pin 2 instead of pin 7
Why? These are repairable
StuckInBulgaria
Posts 25
Silver Member
Beobuddy:
StuckInBulgaria:
Thank You - I am not used to things having a light to tell you they are off - LOL. But i did suspect it may change to green
Will Try - Thank you
I'm English, I live in Bulgaria.  Things that are easy and normal in the rest of the world take on a special kind of "near impossible" here. Smile
stefan
200 miles from Struer
Posts 2,920
stefan replied on Thu, Jul 21 2016 1:50 PM
MCL "P trigger SPEAKER ON/OFF is via PIN 1, ground is PIN 2, as Beobuddy said. If you have a Beovision or a Beosound as source, it helps, when you solder a bridge in the Powerlink from PIN4 to PIN1.
You can find a lot of useful (wiring) information on the Beotech site.
Hope this helps - welcome to Beoworld.
Stefan
StuckInBulgaria
Posts 25
Silver Member
OK - Sorted
Im using the pin numbering as shown in diagrams and schematics from B&O - which is a little confusing.  Starting bottom left and going clockwise we have, solder side on a Din plug:
6, 1, 4, 2, 5, 3, 7
On that layout MY unit switches ON with +5v at pin 1 and 0v to any ground.
On the schematic pin 1 is shown as unused.
As far as I can tell I have:
Pin 1 = Power link on with + 5v
Pin 2 = Signal Ground
Pin 3 = Left in
Pin 4 = Poss Speaker mute?
Pin 5 = Right in
Pin 6 = Poss Data?
Pin 7 = Ground to chassis
Pin 8 = Poss Overload?
However it does switch on with one heck of a thump - I guess this is what the speaker mute is for.  So I need to configure a the position switch so it goes
Standby                  -        Speaker mute
Power on                -        Speaker mute
Power on                -        Active speaker
This is to be driven alongside a Beomaster 1400 for now, volume modulation is done via the source.
StuckInBulgaria
Posts 25
Silver Member
Just to say a thank you to people - who offered advice.  Especially Stefan - why the schematic i had had pin 1 as unused I dont know but it was the one i would never have tried if Stefan had not mentioned it.
Page 1 of 1 (6 items) | RSS
