I am in the mood to buy a new B and O toy. I am considering replacing my 9s with 5s and moving 9s to the rear. I am also considering a second pair of 9s and having 9s both front and back.
Finally I am considering replacing my rear 4000s with either 3s or 11s.
Any opinions on 3s verses 11s as rears?
Edit: I meant 3s verses 12s
The BL11 is a subwoofer... so you can't replace your 4000s with an BL11... you'll need to add some speakers :-)
Do you mean BL3 vs. BL12-2?
Hey there! I have Lab 5's that I upgraded from BeoLab 3's with a BeoLab 2 (at one point dual BeoLab 2's actually) a little over a year ago and after I took delivery on my BeoLab 5's I actually stopped using rears for a while but recently I decided to take the plunge on a pair of BeoLab 12-3's (the white ones are just TOO sharp for me to not want them!!!). I'm considering maybe using them in my living room set up to replace a pair of BeoLab 4000 but I've also debated whether or not I should use them in my bedroom with the Lab 5's. I think the BeoLab 3's are a far superior loudspeaker so the decision to use the 12's as a rear would be purely aesthetic. Regardless I think before I make my final decision I'll at least temporarily set them up in the Lab 5 setup. Once I reach that point I'll be happy to share my opinions on which one is better as a rear!
If you have the space and don't have the same financial constraints that I have I would definitely grab a set of BeoLab 5's and move the 9's to the rear. They're honestly the best investment I've ever made and having lived with them for a year now I couldn't see ever not living with them. My first Bang & Olufsen purchase was a BeoVision 5, BeoCenter 2 and BeoLab 3's. At the time I had thought about only buying BeoLab 5's and an audio system but I figured the complete system was the way to go. 7 years later I barely remember owning a BeoVision 5 and my BeoCenter 2 is merely a decorative trophy mounted to my wall. The second I plugged my BeoLab 5's in and cranked them for the first time all 7 years of buyers remorse almost brought a tear to my eye.
BeoLab 12's do make an incredible visual statement ... but if your choice is between them (or BeoLab 3's of course) and BeoLab 5's you might find yourself regretting not taking the big dip.
Thanks for all of the input. Right now I am thinking I will forget about 3s and 12s and either get a second pair of 9s, or a pair of 5s.
Why not push the boat out and get 5's all round?
Ban boring signatures!
Maab:Unless I missed it... none of these speakers feature any digital input like bl5s, correct? I had hoped the lab12 would have...
As far as I know the BL5 are the only one's with a digital input.
But on the other hand the digital input is a bit of a misunderstanding, since almost none of the B&O equipment feature a digital output.
Only the beosound 5 have a digital output, as from what I've heard it isn't a good one.
The old BS9000 and Beocenter 2 used to have a digital output but both are discontinued.
Beosystem 3 doesn't have one, I never understood why that was left out?
Tompasten:As far as I know the BL5 are the only one's with a digital input. But on the other hand the digital input is a bit of a misunderstanding, since almost none of the B&O equipment feature a digital output. Only the beosound 5 have a digital output, as from what I've heard it isn't a good one. The old BS9000 and Beocenter 2 used to have a digital output but both are discontinued. Beosystem 3 doesn't have one, I never understood why that was left out?
