Hello, I'm new to the forum and seeking advice.
Recently I suffered a flood at home and my Beovision 7-40 was a victim. The Beovision 7 range is no longer available so I am getting together a like-for-like replacement for my insurance claim. I've been in touch with my local B&O dealer and a Beovision Avant 55 is proposed along with a motorized floor stand. The Beovision Avant lacks the integrated DVD player that the Beovision 7-40 had. I have searched but there are a bewildering number of 4K DVD players available.
So, my question is does anybody have a suggestion for a compatible Blu-Ray DVD player that would work with the Avant? The problem is that any player must work in a vertical position to fit in the cradle/bracket attached to the rear of the Beovision Avant to sit alongside my cable box.
Thanks.
Edit. I should have written 'up-scaling' rather than native 4K Blu-Ray player. I'm trying to replicate the functionality of my damaged Beovision 7-40 with available equipment.
I know only of two UHD/BluRay players - the Samsung and the Panasonic.
None of these can be mounted like you want it.
There are tons of 'ordinary' BluRay players on the market nowadays.
A couple of years ago some of these could be used vertical - I don't know of any at the moment.
Looking for a second hand player might be the solution.
Something like this:
https://www.amazon.co.uk/LG-BP730-Upscaling-Blu-ray-Player/dp/B00BD7UVHG?ie=UTF8&*Version*=1&*entries*=0
Search for slot loading BluRay players.
mike2016:Hello, I'm new to the forum and seeking advice. Recently I suffered a flood at home and my Beovision 7-40 was a victim. The Beovision 7 range is no longer available so I am getting together a like-for-like replacement for my insurance claim. I've been in touch with my local B&O dealer and a Beovision Avant 55 is proposed along with a motorized floor stand. The Beovision Avant lacks the integrated DVD player that the Beovision 7-40 had. I have searched but there are a bewildering number of 4K DVD players available. So, my question is does anybody have a suggestion for a compatible Blu-Ray DVD player that would work with the Avant? The problem is that any player must work in a vertical position to fit in the cradle/bracket attached to the rear of the Beovision Avant to sit alongside my cable box. Thanks.
BeoNut since '75
elephant:Post picture please. I had not realised that you purchased your BluRay through STB ! BeoNut since '75
@Aussie Michael
I did not know, that you can (still) buy the Toshiba player from STB Brackets.
I thought, that they only sell (the) brackets.
Can you confirm that?
It would be great news, since these players are practically out of stock elsewhere.
Thanks, Chris.
I only have limited online access at present but what little I can find about a new Avant suggests that it will have a woody finish and Android TV over and above the current model.
I'm really just trying to replicate the function of my ruined Beovision 7-40 which I loved.
Thanks, Millemissen.
It's proving difficult to find anything suitable. It might come down to finding a second-hand player.
Thanks, Aussie Michael.
Only 'things' lost in the flood, thanks. Unpleasant as everything is I am insured and they can be replaced.
I searched the STB Brackets web site but couldn't find anything - except brackets, obviously.
One suggestion was using a Sony PS3 or PS4 as a Blu-Ray player. Not sure if they can be used vertically but I have seen photos of them in this position. Is that a PS4 I can see at the back of your set in the photos you posted?
mike2016:Thanks, Aussie Michael. Only 'things' lost in the flood, thanks. Unpleasant as everything is I am insured and they can be replaced. I searched the STB Brackets web site but couldn't find anything - except brackets, obviously. One suggestion was using a Sony PS3 or PS4 as a Blu-Ray player. Not sure if they can be used vertically but I have seen photos of them in this position. Is that a PS4 I can see at the back of your set in the photos you posted?
Thanks Aussie Michael.
I will do as you suggest and email STB Brackets Monday morning. I plan to mount two bits of kit behind the Beovision Avant - my Virgin Media TiVo cable box (my main source) and this elusive BR player. As far as I can make out my options are,
A Toshiba BDX5500 (not currently available)
A Panasonic BBT-01 (not currently available)
A Sony PS3 (not currently available)
A Sony PS4
I'm hoping I can track down a stock clearance or second-hand Toshiba or other from somewhere.
Incidentally, I have noticed that a new Beovision Avant 55, motorized stand and one of these BD players is actually less expensive that my damaged Beovision 7-40, motorized stand and Beolab soundbar was when originally purchased.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Thanks for the advice. It seems my options are getting narrower by the day.
I searched for a Panasonic Blu-Ray player but it seems they all play only in a horizontal position. What I am searching for is a player that operates in an upright position. It seems my options are very limited.
I am searching for a set-up that will duplicate what I had with my flood damaged Beovision 7-40. A 4K up-scaler is acceptable. I have fired off an email to STB about a Toshiba and awaiting a reply.
I have an Avant 55 paired with the Oppo BDB-105D 4K upscaling.
Works fine, all sources works and is recommended by B&O.
//EA
Beo in white is my thing
Currently own: BeoVision Avant 55", BeoLab 5, BeoLab 18, BeoRemoteOne, BeoPlay V1-32", BeoRemote4, BeoSound 3200, BeoGram 6500 (MMC-1), BeoLit 15, BeoPlay A1, LC2, BeoVision MX7000 and BeoLab 3
Certainly it will work fine with OPPO 105, but that would be hard to mount behind the Avant ;-)
By the way - my I ask - why did you choose the 105 instead of the 103?
Thanks for your reply but, excellent player though it looks, I do not believe that it is capable of being mounted behind the Beovision Avant 55 as any player must be upright and slot-loading.
ErikVonAgnar: I have an Avant 55 paired with the Oppo BDB-105D 4K upscaling.
I also had this setup, but after owning a BV11-46, was really disappointed with the Avant 55 picture and I'm not sure if it will match the BV7-40 for regular TV.
Ditched my Avant 55 and picked up a pre-loved BV12-65 and never looked back! Regular HD TV looks stunning, sport is great and Blu-ray movies are amazing. Not sure I see the need for 4K with this setup.
