Hello,
I want to paint some parts of my Beosound 9000 in the color white.
can anybody tell me how to remove the ribbon plates and the silver plate.
the ribboned plate can be removed quite easily: Push to the left when standing in front of the BeoSound 9000 and with the left hand slightly try to lift the plate. Then while lifting and pushing it can be removed.
The Aluminium plate is quite a job to remove. You should know what you do when dismantling the machine which you have to do when you want to remove it.
While you are a gold member you can download the service manual here for the BS9000. In the service manual the dismantling of the whole BS is described in several steps.
Ralph-Marcus
