Hi,maybe a dumb question but I hope you can help me :-)what I have:- Beolab 7.2 which is currently mounted on- table stand: http://timeless-av.co.uk/wp-content/uploads/2012/06/IMG_6062.jpg
- part of wall mount or complete thing!? It looks like this: http://images.beovienna.at/bangolufs-1380914169-28734.jpgOk, strong and big screws for mounting that hefty baby are required. But do i need additional parts from B&O to mount it to the wall!?
Just a tip, I have wall mounted my Beolab 7-2 with the official B&O wall mount and if I had to do it again, I would go with the stb brackets for the Beolab 7-x :
http://www.stbbrackets.co.uk/en-GB/gallery/beolab-7/beolab-7-close-wall-bracket#image-4
These brackets allow you to mount it closer to the wall which should look better. With the official bracket I find the distance between speaker and wall to be too important.
