beosystem 2 without b&o tv
This post has 11 Replies | 1 Follower
olvisab
Posts 1,391
olvisab Posted: Thu, Jul 28 2016 11:52 AM
hello
should absolutely need a beovision 4 for using a beosystem 2 ?
I just want to test the audio 5.1 output but someone told me that the beosystem 2 won't power on without the beovision/panasonic screen.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
BeoIce
Recklinghausen, Germany
Posts 751
BeoIce replied on Thu, Jul 28 2016 12:39 PM
it will power on but 2 pins have to be shortened before that. don't ask me which pins exactly. I remember this info from a thread on the old archived forum.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
BeoIce
Posts 751
BeoIce replied on Thu, Jul 28 2016 12:58 PM
found the info you need. pins 2+3 of the rs232 connector have to shortened to power up the bs2 without a bv4.
BeoIce
Posts 751
BeoIce replied on Thu, Jul 28 2016 1:10 PM
here's a picture of the rs232 connector and the mentioned pins:
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Jul 28 2016 2:39 PM
You need to do this because the BS2 expects an answer from the screen like "Hi, I am Beovision 4".
To shorten the pins you can use a gender changer and a paperclip.
I did this to setup a BS2 once with an Monitor.
Once set up, you can get a lintronic tt http://lintronic.dk/tt455rt238.aspx to turn on the tv / screen.
And use the Beo 4 to control the devices connected
For the HW 6.x you will need an IR eye, the older version 5.x have the Beo 4 receiver already in the little box (that is why I still have on on the attic...maybe I am testing this as well in the future, our BV 4-42 (HD! with 2 x DVI) is getting too small as a screen for the kids room).
Ralf
olvisab
Posts 1,391
olvisab replied on Thu, Jul 28 2016 3:50 PM
Thanks a lot Martin and Ralf for such informativ answers !
olvisab
Posts 1,391
olvisab replied on Thu, Jul 28 2016 5:18 PM
If the rs232 plug is the same than the one on the computer mother board for the screen, I have already the good connector.
I use one for a motherboard that didn't want to power on if a screen was not plugged.
olvisab
Posts 1,391
olvisab replied on Sat, Sep 17 2016 2:57 PM
Hi
tried wirh the digital output of a sony bluray player and the digital input of the beosystem works flawlessly.
i still have issue for displaying the menu with the rgb output on my computer screen.
last time the screen displayed the menu but not all the time but I could modify things easily. This time it doesn't display anything. I tried with another old computer lcd screen and nothing more.
kallasr
Germany
Posts 2,562
kallasr replied on Sun, Sep 18 2016 11:46 AM
Your computer monitor needs to take RGBHV 575P 50 Hz as input signal. You could get an Philips Brilliance 109P for example (that is what I used some years ago).
Ralf
1990
Posts 521
1990 replied on Sun, Sep 18 2016 2:28 PM
Is there any way to connect it through a VGA>HDMI converter to a modern-day Full HD TV?
olvisab
Posts 1,391
olvisab replied on Sun, Sep 18 2016 5:37 PM
Hi ralf,
you are still always helpfull ! Very important information.
A crt monitor should be able to deal with this resolution.
olivier
olvisab
Posts 1,391
olvisab replied on Sun, Sep 18 2016 5:44 PM
That won't resolve the issue concerning the resolution. The pb is that modern screen are not able to display it.
Page 1 of 1 (12 items) | RSS
