Direct TV and V1 Remote
This post has 7 Replies | 2 Followers
peria
Posts 321
peria Posted: Mon, Aug 1 2016 6:55 PM
Does any one have a V1 connected to a Direct TV Genie? I am not able to control this usung the IR codes listed on the V1. Help?
Once upon a time in the USA we had some local support, no longer do we have many local stores here.
Thanks.
Millemissen
Flensborg, Denmark
Posts 14,680
Is your receiver in ir mode?
peria
Posts 321
peria replied on Mon, Aug 1 2016 8:05 PM
The receiver is in IR mode. If you have it connected to a DirectTV Genie, then mine should work as well.
The following are true:
1. IR from V1 will control other cable boxes like a Tivo (no longer used with the DirectTV Genie) - Yes
2. Direct TV Genie is in IR Control - Yes
3. Genie is responsive to IR Controls not to RF - Yes
4. Locate the IR Receiver window on the fromt of the Genie. - Perhaps
expoman
Posts 182
Silver Member
expoman replied on Tue, Aug 2 2016 4:40 AM
 Do you have a B&o approved IR flasher connected to the V1 and taped on the front of the Genie?
Use a flashlight on the front of the Genie to see the location of the IR receiver. You may have the flasher in the wrong location. The range of the flasher is very short.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi peria,
The range of the original B&O IR flasher diodes is quite short (sometimes just a few cm).  I've managed to obtain some diodes that give up to 1 metre of optical range, so if you have trouble getting the B&O ones to work, then these may help:-
http://soundsheavenly.com/televisions/60-ir-transmitter-blaster-for-beosystem-4-beoplay-v1-and-beovision-11avant-rj45-control-socket.html
Kind regards, Steve
Steve.
www.soundsheavenly.com
peria
Posts 321
peria replied on Wed, Aug 3 2016 7:48 PM
I am assuming that the IR receiver on the Genie is on the left hand side?
Thanks all for your suggestions. I will try these, and if necessary order the IR blasters from Steve.
peria
Posts 321
peria
Posts 321
peria replied on Sun, Aug 7 2016 1:54 AM
Thanks gentlemen. IR now working. Very difficult to exactly locate IR window.
Page 1 of 1 (8 items) | RSS
