Beosound + Behringer DCX2496: How? Maybe a question for Mr. Geoff Martin
TWG
Posts 1,672
TWG Posted: Wed, Aug 3 2016 10:35 AM
Hello,
as I'm using a non B&O subwoofer with my Beosound and Beolabs. I want to fine tune everything and want to integrate a Behringer DCX2496 speakermanagement system:
https://www.music-group.com/Categories/Behringer/Signal-Processors/Loudspeaker-Management-Processors/DCX2496/p/P0B6H
My idea is to split the powerlink output of the beosound:
- Audio output of the Beosound into the Behringer DCX 2496
- The control signals of the powerlink output of the Beosound will not be routed through the DCX2496, only the audio part.
- audio output of the Behringer 2496 will be split: The high cut signal will go to the subwoofer and the low cut signal will go to the beolabs.
I've bought cinch-xlr-cables BUT the signal level of the Beosound into the Behringer is extremely low. Do I need other cables or does anybody use a similar setup? I can not exclude a "user 40 error" ;-)
As the Beolab 1 where intended to be used with the Beolab 2: Can somebody tell me the crossover freqency of the Beolab 2?
Any help is appreciated. :-)
Killyp
Posts 55
Killyp replied on Thu, Aug 4 2016 2:15 PM
The DCX2496 is expecting a high-level professional input, while the BeoSound has a much lower output level.
Personally I would strongly suggest you look at a high quality crossover rather than the budget Behringer which has very noisy AD/DA converters and IMO rather poor sound quality.
DEQX make a great alternative, not cheap though!
Page 1 of 1 (2 items) | RSS
