beo passive amp
This post has 9 Replies | 0 Followers
oddball
Sunderland
Posts 11
oddball Posted: Sat, Jul 28 2012 5:40 PM
Hi to all ,iv'e a beolink passive amp with beovox 3000 flat panel speakers and would like to connect to my Advant tv which cable will i need cheers Shaun
MartinW
Posts 389
MartinW replied on Sat, Jul 28 2012 6:50 PM
Just a masterlink cable from tv to passive, works a treat! The Avant has fantastic sound.
oddball
Sunderland
Posts 11
oddball replied on Sat, Jul 28 2012 8:43 PM
Hi Martin thanks for the reply any idea were i might be able to buy a masterliink cable ,or is there anybody on this forum selling 1 cheers Shaun
Nick
Nottingham
Posts 785
Nick replied on Sat, Jul 28 2012 8:50 PM
oddball:
try Steve at sounds heavenly
Cheers Nick
Nick
Nottingham
Posts 785
Nick replied on Sat, Jul 28 2012 8:52 PM
you can also use a fully wired powerlink(speaker) cable, it depends on what you are thinking of using the speakers for? if its in the same room to give a stereo sound from the tv then powerlink is what you want.
oddball
Sunderland
Posts 11
oddball replied on Sat, Jul 28 2012 9:09 PM
Hi Nick ,yes i want the speakers in the same room as extras iv'e acquired a   power link cable i think (as the power link got round 7pin din on each end ) if so iv'e got this but can't seam to get sound though the beovox, iam not sure were to connect on the AVANT, read manual and looked on net but can't seam to find any info .there 5 places to put cable but not sure which 1 if any ,your advice will be much appreciated cheers Shaun
MartinW
Posts 389
MartinW replied on Sun, Jul 29 2012 9:30 AM
Any B&O dealer could supply you with the cable
Nick
Nottingham
Posts 785
Nick replied on Sun, Jul 29 2012 9:43 AM
you need to plug it into a front speaker socket on the rear of the avant, then go into the avant settings and tell that it has got speakers plugged in. I chose beolab 4000 for mine, and if your powerlink cable is fully wired it should turn the amp on and away you go!
The only thing i will say is that the avant speakers are better than the beovox but the stereo will be wider effect!  The beovox would make great rear speakers in a surround sound setup!
Cheers Nick
oddball
Sunderland
Posts 11
oddball replied on Tue, Jul 31 2012 9:20 PM
Nick sorry for the late reply ,your a true gent worked a treat you were right does sound alot softer but pleaseing to the ear cheers again
Nick
Nottingham
Posts 785
Nick replied on Tue, Jul 31 2012 10:31 PM
your welcome, glad I can be of some use
Cheers
Page 1 of 1 (10 items) | RSS
