Sky Q Goes 4K Live..
This post has 16 Replies | 0 Followers
Bv7Mk3
uk
Posts 781
Bv7Mk3 Posted: Thu, Aug 4 2016 7:42 PM
Take a peek and Sky Q goes live 14th Auguest..
http://www.insideci.co.uk/news/sky-q-goes-live-early-with-4k-uhd-pre-season-fixture.aspx
Alex
Essex
Posts 64
Alex replied on Fri, Aug 5 2016 10:14 PM
all Live now!!! Looks awesome!
Simmy
Posts 4
Simmy replied on Sat, Aug 6 2016 8:39 AM
I am having problems with my avant. Is there something in the TV settings I need to do? Sky won't switch as TV screen goes blank when on ultra hd, thus reverts back to 1080.
markaby
Posts 13
markaby replied on Sat, Aug 6 2016 10:01 AM
I'm having the same problem , does anyone have a solution ?
Simmy
Posts 4
Simmy replied on Sat, Aug 6 2016 10:42 AM
I am running the latest software so HMDI input 1 should be okay. I am running a splitter to two avants and I have now tried both separately and get the same result on both televisions.
Simmy
Posts 4
Simmy replied on Sat, Aug 6 2016 11:16 AM
Are you using a 4K HDMI cable? There was one provided with the box. It is not long enough for my set up, but I am pretty sure my cables are 4K compliant.
Alex
Essex
Posts 64
Alex replied on Sat, Aug 6 2016 9:12 PM
i kept trying and then it worked
i thought it was the matrix setting but i guess not
now i have 10bit UHD it even shows it on the signal info as 4k
Bv7Mk3
uk
Posts 781
Bv7Mk3 replied on Sat, Aug 6 2016 9:19 PM
How do you find the picture?
Simmy
Posts 4
Simmy replied on Sun, Aug 7 2016 11:13 AM
Sorry lots of questions....
Did you get the 'we can't detect an Ultra HD screen' page? I only get this when going through the splitter. I can continue passed this, but then get error UH011 - this input on your TV does not support Ultra HD. I am using a 4K splitter.
If I remove the splitter I can get to a page 'setting your picture resolution to Ultra HD' I continue and it tries 10 bit and then goes blank and then returns to the same page.
Did you change any settings in the TV?
What HDMI cables are you using and what length are they? What matrix are you using? And finally which port are you going into on the TV?
Thanks in advance.
markaby
Posts 13
markaby replied on Mon, Aug 8 2016 7:57 PM
I thought all ports on the TV were UHD combatale escept the easy access port
markaby
Posts 13
markaby
Posts 13
markaby replied on Mon, Aug 8 2016 7:58 PM
I thought all ports on the avant were UHD compatible except the easy access port ?
Bv7Mk3
uk
Posts 781
Bv7Mk3 replied on Mon, Aug 8 2016 9:34 PM
NopeSad only number one!
markaby
Posts 13
markaby replied on Tue, Aug 9 2016 8:56 PM
I think I have port one connected to my Oppo DVD, I'll have to change them over, thanks for letting me know
markaby
Posts 13
markaby replied on Fri, Aug 12 2016 8:01 PM
Is that HDMI 1 ?
markaby
Posts 13
Is that HDMI 1 ?
markaby
Posts 13
markaby replied on Fri, Aug 12 2016 8:02 PM
Is that HDMI 1?
Page 1 of 1 (17 items) | RSS
