Beolab 8000 + sonos connect.
This post has 8 Replies | 2 Followers
Majkk
Posts 4
Majkk Posted: Thu, Aug 4 2016 10:35 PM
I have a problem with my sonos +beolab 8000 system. One of the speakers do not turn on if they are in (L) and (R) possision? There is allso a bit of noise from the speakers when they are not playing?
Razlaw
Posts 4,345
Razlaw replied on Fri, Aug 5 2016 1:38 AM
Welcome to Beoworld!   Is the problem new to an existing system or are you setting the system up for the first time and having the problem?   How are you connecting the Sonos to the 8000s?
Weebyx
Denmark
Posts 1,213
Weebyx replied on Tue, Aug 9 2016 10:52 AM
Majkk:
I would think that both speakers should be in Line position.
L/R is used when they are connected via Powerlink, which has both Left and Right signals. I guess the Sonos outputs Left and Right as 2 different line signals, so they should just be connected to the Line on BL8000
/Weebyx
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Majkk,
Welcome to BeoWorld!
Beolab 8000s should work perfectly with Sonos Connect, without any background noise.  The description below applies if you just have the speakers and Sonos connected, ie. no B&O music system or TV.  Please remove any 8 pin Powerlink cables from the speakers, as these aren't needed.
Please set both speakers to "Line" mode using the small switch next to the input sockets.  The choice of cables is important to prevent background noise, if your are hearing noise through the speakers then the existing cables may be unsuitable.
Here are the cables you need to connect the Beolab 8000 speakers to a Sonos ZP80/90/100 or Sonos Connect:-
http://soundsheavenly.com/line-in-connection/6-av-processor-pre-amp-sonos-to-beolab-rca-line-in.html
Volume control is arranged via the Sonos, ie. from your smart phone or tablet.  The speakers should now turn on automatically when the music plays and they should turn off three minutes after the music has stopped.
Hope this helps!
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Majkk
Posts 4
Majkk replied on Thu, Aug 11 2016 9:09 PM
Thank you for your answers! I have the system hooket up, and today one of the speakers turned on and of, when the system was turned of. When i looked at the cable, the pin sticking into (line) was broken. Can this be the reason why it turns on/off? This is fearly cheap cables....
Beold
Denmark
Posts 69
Beold replied on Thu, Aug 11 2016 10:10 PM
Sounds like you need new better cables
Office: Beomaster 3000-2 with Beovox P45 (all in white)
Living room: Beomaster 7000 and Beogram 7000 with Beovox RL 7000 (all in white)
Kitchen: Beocenter 2300 with Beovox 4500 (not available in white :-(
Majkk
Posts 4
Majkk replied on Fri, Aug 12 2016 10:23 PM
Do you have this cable in 10 meters and white? Wifeys demand...
Majkk
Posts 4
Majkk replied on Fri, Aug 12 2016 10:24 PM
Do you have this cables in 10 meters and white?
Posts 2,165
Hi Majkk,
No problem!  Here is a link to the cable in white at 10m lengths (there is a choice of 10 colours for this version of cable):-
http://soundsheavenly.com/line-in-connection/93--rca-rca-super-.html#/colour-traffic_white/length-10m
My standard cables in blue work out cheaper, but this "high-end" cable gives you the best sound and the choice of colours.
Steve.
Page 1 of 1 (9 items) | RSS
