Beolab 4 p.c
This post has 7 Replies | 0 Followers
bramble
Posts 397
bramble Posted: Fri, Aug 5 2016 12:16 PM
Hello,
 looking for some help, just got myself a pair of the above speaker....for a great price, have hooked up to my bv5 as a surround set up
I have set them to auto, and have upgraded my power link cables to mk3 and bought the others required from sounds heavenly ( thanks Steve)
my problem is they are not going into standby mode ......and it sounds like the speakers are rec a signal
i have tested the bl4's with there other cable and my phone.....and no issue.  They go on and off as should
any ideas?
system beovision5.  Bl4's  all round. And a linn sub.....ml to bs3000
ta
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
elephant
AU
Posts 8,219
elephant replied on Fri, Aug 5 2016 12:46 PM
I have BL4s and use them as rears for a BV8. I don't have your symptom.
I checked my switches:
Position: 1, 2, 3
PL or Line in L, R
I think mine are the full version rather than PC version.
Is that why you have an AUTO switch ?
BeoNut since '75
bramble
Posts 397
bramble replied on Fri, Aug 5 2016 12:51 PM
I have a pair of power link version  & p.c
but it's just the issue with the p.c type.......just won't go into standby mode
even when I swap speakers over and use different cables.....still the same.
Aussie Michael
Melbourne, AU
Posts 3,730
They will go in to standby when you take them
Off auto funnily enough
bramble
Posts 397
bramble replied on Fri, Aug 5 2016 12:59 PM
Ok will try auto off
bramble
Posts 397
bramble replied on Fri, Aug 5 2016 1:01 PM
Speakers still sound like they are getting a signal
set to auto off.....how long should it take, as the power link is instant.
bramble
Posts 397
bramble replied on Fri, Aug 5 2016 1:10 PM
Aussie Michael .....have a beer....works a treat
crazy......many thanks to all
Aussie Michael
Melbourne, AU
Posts 3,730
bramble:
Beovision 5,beovision 6x2, beosound 3000, beosound 1, beogram 3000, 2 x lc2, 2 x beocom 1401, beocom 6000, 5 x beo4,
beolab 6000, beolab 4's, form 2, h2, a2, beosound 3, linn subwoofer .
Yep. I had the same issue with mine. Glad it worked out for you.
I thought perhaps because in Australia we are upside down SadBig Smile
Page 1 of 1 (8 items) | RSS
