Does anyone know if the following configuration is supposed to work? I have a pair of wireless1's extending my ML network. I have both an Active and Passive connected to the receiver wireless (via ML junction box). This usually works, but with undesired side effects - turning off the Passive often also turns off the Active, and sometimes the Active must be activated before I can get the Passive to work.
I bought both Active and Passive used so I don't know how old they are. Could a software update fix this? Or is this configuration not supported and I'm lucky that it works at all?
Stan
Sorry Stan, I don't know - and I can't test as I don't have a passive. I hope one of our technically knowledgeable folks (some of them are dealers) will answer you !
BeoNut since '75
Stan: I bought both Active and Passive used so I don't know how old they are. Could a software update fix this? Or is this configuration not supported and I'm lucky that it works at all?
A "ML-Sub-Net" using a juntion box to distribute the ML of a Wireless receiver is NOT supported the "side effects" you are describing are the result !
You can use EITHER PowerLink OR MasterLink on a Wireless receiver at the same time .
A SW-update to recent version of ALL components is strongly recomended!
BUT:
To expand a ML-Network :You are able to connect up to 7 wireless recievers to each transmitterYou can install a maximum of 3 wireless transmitters to further expand the ML-Network(in theory this means 3 x 7 = 21 rooms)To each wireless receiver you are able to connect :- via PowerLink active speakers- via PowerLink (fully mounted) a BeoLink Passive w/o IR eye (= ML/MCL converter) to drive pasive speakers- via MasterLink a BeoVision TV (with ML connector) - via MasterLink a BeoLab 3500
RECOMMENDATION:- Buy a 3rd Wireless, set it as a receiver and connect the Passive via a fully mounted PL cable- A BeoLink Wireless, if set to receiver offers all possibilities of a BeoLink Active - use the Active for a further (wired) zone or sell it. - Check SW versions and update, if necessary all components to recent versions ( keep in mind SW update for active and passive is done by exchanging EPROMs)
Thanks Vienna, I was pretty sure that was the answer (not supported) and the solution (buy another wireless). Note that I am not using the PL socket on the wireless, only the ML. I guess I should have bought a 3rd wireless instead of the Active... Oh well... I got it for a good price.
I live near one of the main US service centers so upgrades are not a problem.
Do you happen to know if 2 receivers placed near each other will interfere? That is why I went down this current path as I had some difficulty in finding a reliable location for the first receiver, and felt adding another would potentially compound the problems.
Unless you are using analysing equipment & software for several thousend $ / EUR, WiFi is always a bit "try and error"
A BeoLink Wireless, if set to receiver offers all*) possibilities of a BeoLink Active !Use the BeoLink Active for a further (ML-wired) zone or sell it.
EDIT:*) except the PC input - beeing exclusively available on the BeoLink Active Important if you want to connect a local source e.g. a Playmaker for local streaming, a non B&O source,.... to your B&O speakers.
